Home > Maintenance & Mods (L322) > Lumpy at 1600-1800rpms TDV8 -Sorted
Mikey
LH side, buried up above.the front diff. Excellent design Rolling Eyes
Post #322613 14th Apr 2015 6:29pm
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
Don't really want to take it to the dealer as they will probably try and get a new turbo out of me.
Will try to get access and see how it looks.
[Workshop manual says, remove first diff, remove cat, de gas air con...]
Post #322619 14th Apr 2015 6:51pm
Mikey
http://www.fullfatrr.com/forum/topic31324.html
Post #322622 14th Apr 2015 7:08pm
stenh02
I was reading on the RRS site that you can view the LH turbo from beneath the car and possibly get a screwdriver on the rod to see if it moves.
I put my head under the car and saw the exhaust down pipe but thats about it. I suppose the diff is in the way and the turbo is lurking above that.
Post #322771 15th Apr 2015 8:38pm
stenh02
Fullfat at the Indy today and they lubricated both actuator levers. They now both do a full 3 or 4 'wiggles' after ignition shut off.
Thumbs Up probably need to give it a good blast now then. Only do 9.5 miles to work and back a day so that's probably not helped matters.
Thanks for the help.
Post #323499 21st Apr 2015 5:25pm
