![]() | Home > In Car Electronics (L322) > Picking up a reversing wire - android head unit |
If you go to the Lighting Control module located in the drivers footwell behind the trim panel you should find a White/Yellow wire coming off it. That wire is the +ve 12V feed for the reverse lights which should meet your needs.
Stuntman Member Since: 27 Dec 2014 Location: Norfolk Posts: 67 ![]() ![]() ![]() |
Brilliant thanks,
