![]() | Home > Technical (L322) > Is my head gasket on its way out |
Mph28mph Member Since: 16 Jun 2013 Location: Wigan Posts: 112 ![]() ![]() ![]() |
I have recently put my rangie up for sale.
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
Not necessary so.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3244 ![]() ![]() ![]() |
The cooling system is pressurised. Ergo, if you remove the filler cap when the system is still hot,ie pressurised, you get steam or water ejecting. There is a warning on the filler cap.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8376 ![]() ![]() ![]() |
Yours has a 110deg thermostat so the water will be hotter than boiling anyway, the reason it doesn't boil over is that water boils at a higher temp when under pressure, if you remove the cap it will boil immediately as it's hotter than 100deg C....
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16312 ![]() ![]() ![]() |
Its probably a slimy motor traders trick!
Thanks all for the quick replies. You have put my mind at rest. |
Your welcome sir |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 869 ![]() ![]() ![]() |
I'd make sure you check levels when cold. You can lose quite a bit when some bell end takes the lid off when hot |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
I'll take it if he doesn't want it.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
What a knob! Maybe you could have countered him, by removing his cap on the car he came round in.
Driving down through France on the motorway once when I was younger and having stopped at a rest area I remember seeing a young man remove the cap on the radiator not long after he pulled in.
OUCH!!! lesson to be taken onboard there by all |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Saw somebody do the same outside my house about 15 years ago, tried to open the window to shout him to stop when I saw what he was trying to do but I wasn't quick enough - tank erupted all over his face and arms - his passenger quickly bundled him into the passenger seat and drove him away, sounded painful, didn't even refit cap before driving off. |
