Home > Technical (L322) > Rust Repair? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8499 |
Looks like a fairly normal amount of surface corrosion on the subframe and anti roll bar, given the age of your car. Probably worth having a DIY go at it with some rust remedy and satin black or stone chip even if it's just applies with a brush. Followed by a coat or 2 of waxoyl underbody protection.
12th Mar 2015 7:45am |
brucebaner1 Member Since: 03 Feb 2015 Location: Virginia Posts: 8 |
Thank you sir! I just noticed the fluid is noticeable in the pics (pic 4). Could you possible know what it is from the pictures? It is oily to the touch. |
12th Mar 2015 11:23am |
tricky to see where that could be coming from there, i would suggest having a poke around in the front left of the engine bay to see if there is any leaks evident from the cam cover gaskets or such like. it is not obvious where it may be coming from but it does look like it has dripped down from above, have a quick check of all the gaiters on the steering arms and driveshafts to see if there are any splits and its coming from there also, but that would be more like grease. There is nothing that can't be fixed with a hammer😜😜
12th Mar 2015 6:02pm |
Thanks again. I will admit that I had the car jacked for about 4 days (right wheel hub would not release wheel); I did notice the leak after it was sitting upright for awhile. |
12th Mar 2015 8:36pm |
