![]() | Home > Camping, Caravanning and Holidays > Towing Laws |
markdotreed Member Since: 05 Sep 2011 Location: Ropley Posts: 741 ![]() ![]() |
Does anyone know the towing laws of towing a twin axle trailer with only one axle fitted?
The axle is not structural, it carries weight but does not add to the structural rigidity of the trailer so perfectly legal as long as the overall weight is lower than the rating for the remaining axle. Remember to subtract the weight you have on the towball (100KG-ish) as this weight will not be on the axle as well.
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
Done it a few times as well as just taken the front wheels of a twin axle when one them got punctured and I didn't have a spare.
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
Check that the brakes still work as they normally have a split from one rod/cable to two so if one is missing the other may not work. |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
Towing it should be fine if not going far!
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16332 ![]() ![]() ![]() |
Make sure the single axle's brakes are rated for the whole trailer?
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
I'm in agreement with Craig on this . . .
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
Or think of it as a semi-permanent lifting axle? |
