Thanks ironhorse, then I definitely need the change over valve (the famous number 24 on the drawings)
Wondering if this can be bought at at reasonable price somewhere and even more wonder if the wiring is then already there to connect it....anybody happen to know this and the partnumber?
Also, the FBH is producing "x" amount of heat. Without the change over valve, I think it means that the FBH is using this to heat both circuits (whereas the thermostat is closed). So as the "total amount of heating" is not changing, it means that if the interior would be "toasty" (forget about the fans for the moment), then the engine would actually be colder?
Workshop manual:
"The changeover valve isolates the heater coolant circuit from the engine coolant circuit"
Changeover Valve
"The changeover valve is a normally open solenoid valve installed between the supply and return sides of the heater coolant circuit. The changeover valve is located in the engine compartment on the engine bulkhead. When deenergised, the changeover valve connects the heater coolant circuit to the engine coolant circuit. When energised, the changeover valve isolates the heater coolant circuit from the engine coolant circuit. The changeover valve is controlled by a power feed from the ATC ECU."
On receipt of the messages:
- A red LED on the MID/MFD panel flashes at 2 Hz to indicate that parked heating is active.
- If the ambient temperature is less than 5 °C (41 °F), the BCU activates the door mirror heaters for 3 minutes
The ATC ECU
- Energises the changeover valve
- Sends a K bus message to activate the FBH
- Operates the blower at speed 1
- Opens the windscreen distribution flaps in the heater assembly and closes the face and footwell flaps.
My outside mirrors by the way for sure are not heated for 3 minutes below 5 degrees C outside temperature, but that probably is another problem not related to the current dicussion Range Rover Vogue, MY '06 TD6 3.0 Tonga Green
