Home > Technical (L322) > LOTS of bongs today - some advice required if possible
dingg1
been away at work for the day and on getting picked up from the airport I was greeted by the missus saying ' I think we have a problem with the car' oh dear or words to that effect says I.
the bongs have been - HDC fault not available
-Transmission fault traction reduced
- engine speed sensor A fault and rear right wheel sensor - the engine speed sensor appears to have cleared
- park brake fault
dash lit up like blackpool lights and car on lowered suspension.
the following codes were cleared and reappeared quite quickly and the car bongs the above again apart from the engine sensor issue.
ATCM codes - u0401 invalid data from ECM/PCM
-U0402 invalid data from TCM
-U0416 invalid data from vehicle dynamics control module
-U0403 invalid data from TCM
-U0421 invalid data from suspension controle module
park brake code - u0416 ^as above
RDCM rear diff code - u0122 (fuel and air metering ) lost comms with vehicle dynamics control module
TCCM transfer case code u0136 - (fuel and air metering ) lost comms with diff control module rear.
I also had a rear right wheel speed sensor alarm but that has cleared -
Now then has anyone got a clue for me where to start on this ??
ie could it be a common issue giving all of the above
any advice/help is welcome
thanks in advance
ps my first train of thought is the right rear wheel sensor is duff and f@@@@ing everything up
Post #315024 26th Feb 2015 8:11pm
First port of call is to check the battery voltage and charging rate... Pete
Post #315026 26th Feb 2015 8:23pm
dingg1
battery shows 14v when cars running but I will stick it on a conditioner for the night
thanks for the prompt
Post #315028 26th Feb 2015 8:32pm
Rovertech
United States
Sounds pretty typical steering angle sensor or wheel speed sensor.
Post #315197 27th Feb 2015 1:56pm
dingg1
speed wheel sensor is my best suggestion too as its still showing a DTC - going away to work for 2 weeks so will sort once back .
Post #315207 27th Feb 2015 2:18pm
wealy
United Kingdom 2014 Range Rover Vogue SDV8 Luxor
Did this clear itself?
Any more trouble?
Post #316699 7th Mar 2015 9:53am
dingg1
still at work , will update once sorted
Post #316757 7th Mar 2015 7:25pm
dingg1
Well I have changed the right rear abs sensor - eventually - it broke off in the hole and a drill was needed to get the damn thing out.
anyway the problem has not gone so any one have any ideas ?
the codes showing are :-
ATCM U0401,U0402,U0403,U0416.
TRANSFER CASE U0122,U0136
REAR DIFF U0122
PARK BRAKE U0416
VEHICLE DYNAMICS - RR SPEED SENSOR CIRCUIT C1A93
they mostly appear to be comms issues
any pointers from someone who knows what the likely cause/culprit would be good
cheers
Post #318572 18th Mar 2015 2:42pm
dingg1
Time to update this now as everything is sorted
the first issue was a failed right rear speed sensor , this I changed with a part from ebay which was listed as for my car
I changed the sensor , but the original was stuck in place so had to drill it out . After fitting new sensor still had the 3 fault lights and no signal from RR speed sensor , sent car for diagnostics to independent in tyne and wear, after 2 hours diagnostics they told me abs ecu goosed all circuits are ok all speed sensors are ok MUST be abs ECU.
rather that take their word for it and fork out about 2k I decided to fit a second hand unit, this was after dismantling my ecu and finding nothing of obvious concern with the naked eye.
I fitted the second hand ECU and still had the no signal from RR speed sensor and the 3 lights of doom - so either the ECU has the same fault or the fault lay elsewhere - I double checked all resistances and circuits to each speed sensor and discovered eventually that the one I had changed was way above the others. so either a failed new sensor or the wrong sensor fitted.
It turned out that the wrong part had been fitted by me due to the listing on ebay , the sensor should have been ssf500021 , but the vendor had supplied ssf000021 - arghhh .(how had the independent well respected garage not picked up on this I don't know as the resistance checks should have been part of their diagnostics)
once the proper sensor had been fitted I managed to have all speed sensors working BUT after a few yards of driving still got the bongs and 3 lights - this turned out to be a new code that was the pressure sensor within the abs module failure - this was a new code and I guess it came about after I had really stamped on the brakes to test whether the abs system was working a few days before .
I then decided that the only thing to try was to change out the HCU as the pressure sensor circuit is both in the ECU and HCU - now the problem is fixed after a lot of Censored about.
the morale is - check check and double check parts are correct - If I had checked correctly all my woes would have been resolved with a simple sensor change out for about £50 instead I have bought two new sensors which are not for my car and wasted time and most likely Censored a good abs module that wasn't needing changing in the first place.
at least the problem is sorted now.
ps also discovered some scrote has stolen both rear wheel arch bits of trim that clip on the lip of the arch
ETA - lots of help from Patrick at GAP who had the patience of a Saint
Post #324802 28th Apr 2015 3:07pm
Glad you got it sorted, sounds like a right pain in the bum.... Pete
Post #324896 29th Apr 2015 1:41am
dingg1
Pete
it was a bit of a nightmare tbh - especially with misinformation and wrong parts , a catalogue of Censored which lead me down the wrong path.
One of the things I also changed out was the brake pedal switch (this can also cause some of the similar/same issues) this is a bastard to get to and you need to be somewhat of a contortionist to change it out.
the thing I was trying to avoid was changing out the HCU as I expected to need to take the car to get bled properly using the software at a garage - fortunately I have encountered no issues whatsoever - the brake pedal is ever so slightly spongier than it was previously , this is without even carrying out any bleeding!
I shall do it at the weekend when more time is available , but I am really surprised that no other issues , all I did was put clingfilm over the reservoir top to hold vacuum to minimise loss , and on disconnect of brake pipes at HCU plug each open end with bluetack to stop air ingress , I then used a syringe to prime the HCU through each port before reconnect and all is good.
I also tested the brake efficiency and all was well so went to a nice steep hill and used HDC to get the system going and all is working fine.
Post #324899 29th Apr 2015 6:09am
