Home > Technical (L322) > Brakelights/Switch. L332 TD6. Hdc inactive/Air susspention
Dazzler
England 2003 Range Rover Vogue Td6 Zambezi Silver
Evening All,
Well the on going problem continues. Checked all multiplugs on suspention /Abs sensors etc all dry. Changed Brakelight switch a few days before as lights were flickering and staying on sometimes. Got one from LR Direct a Britpart one fitted it lights all good, still suspention faults. Scanned up Brakelight switch fault still reading up and wont clear.Went to a LR Specialist the only thing that read up was again Brakelight switch again it wouldn't clear on his LR Scanner. So I put a Genuine switch from main dealer put it on en low en behold the brakelights stayed on permanently Crying or Very sad . Air suspention and abs lights still on. Put the Britpart one back on brakelights worked fine again???. Could the problem be the Light circuit module??. Anyone know where its located. Any Suggestions Greatly Received Thankyou Darren
Post #315022 26th Feb 2015 7:55pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Look behind your fusebox, if there is a aftermarket handy freespeech installed for example from NOKIA, and how old is your battery? If older then 3 years, please NEW, even if is ok! The brakelight Problem I solved with new battery... L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #315029 26th Feb 2015 8:34pm
Dazzler
Thanks for your Reply fitted new battery last week.
Post #315036 26th Feb 2015 9:07pm
Is it fully charged though?
Post #315038 26th Feb 2015 9:21pm
Dazzler
I would believe so from factors and straight on . FF started ok etc
Post #315043 26th Feb 2015 9:50pm
