Home > Maintenance & Mods (L322) > Replaced thermostat, but......
pietertje
Netherlands 2002 Range Rover Vogue 4.4 V8 Java Black
Recently replaced my 2002 V8's thermostat. But,.... as you can see in the pictures underneath the original connector has been replaced in the car's history by two simple connectors. Thing is I have no Idea how to connect the "connector" back to the thermostat.
So, when looking at the thermostat attached to the engine from the front of the car, would the red or brown wire be left or right?
Thanks!
Post #325802 3rd May 2015 5:21pm
Zirconblue
to be honest the 'sensor' is just a simple thermistor, current can flow either way, so it shouldn't really matter which way they go back on.
The proper connectors are cheap enough, it's just a standard timer housing connector, Maplin, RS, vehicle wiring products all do them for a couple of quid.
Post #325833 3rd May 2015 6:51pm
Doesn't make any difference....
It's just an electrical heating element..... Pete
Post #325834 3rd May 2015 6:53pm
Zirconblue, sorry you type faster than me.... doesn't make any difference but that one is the electrically controlled stat, it's a heating element to open the stat more when the ECU "thinks" the engine may need it.... Pete
Post #325836 3rd May 2015 6:56pm
Zirconblue
Ahh ok, i see. I just assumed it was a temperature sensor. But as you say same net result when it comes to connecting it up. Smile
Post #325842 3rd May 2015 7:04pm
pietertje
Thanks for the replies. So no worries about how to connect it. great Thumbs Up 2002 L322 V8
Post #325904 4th May 2015 7:53am
