![]() | Home > Off Topic - Other Cars > Does LR make "SOME" of the worlds most dangerous v |
drivesafe Member Since: 19 Mar 2008 Location: Gold Coast Posts: 126 ![]() ![]() ![]() |
BTW Stan, I agree with you about a specific batch of faulty alternators and they were in other models at the time. Do you have any idea how many were fitted? 2007 TDV8 Lux |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
Can I suggest this thread is renamed "Let ME tell you how crap YOUR Land Rover is!"
First off Ric, I didn’t introduce alternators into this thread.
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1261 ![]() ![]() ![]() |
'First off Ric, I didn’t introduce alternators into this thread. '
Thanks Paul and you are correct.
Double yawn
So I am dishonest? FY Drivesafe - all vehicles have issues. I've had FOUR RR's and a plethora of other LR's and barring the 2.5V6 Freelander NONE have ever failed me (and to be fair the V6 only chomped a HG but did get home). Land Rover Addict XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8742 ![]() ![]() ![]() |
Just for info, the recommended replacement alternator for the tdv8 is a denso unit, which is the same one which comes in the car when it is put together and the same one as LR sell branded in their packaging. When I searched for replacements when mine failed there wasn't any other options, I could have had a Lucas unit but to be honest when I researched the replacement I discovered that they now seem to specialise in remanufacturing rotating electrical components and don't anctually make new ones any longer (so it would be a denso rebuilt by Lucas)
discowill Member Since: 07 Jan 2015 Location: Wigan Posts: 47 ![]() ![]() ![]() |
I have had 2 alternators fail on 40 plus Land Rovers so they can't be that bad, funny enough they were both 2007 cars one being a Disco 3 and the other a FFRR, the other thing when both of these were failing (did not know at the time no warning lights) for a few weeks before I noticed a slight wearing noise when cold and just put it down to the belt needing changing as this went within 30 seconds I did not think much about it. They fail in a funny way as I would of expected either the battery light to come on (no charging) or the belt to snap with the bearings seizing but nothing then one day the dash lit up like a Christmas tree, turn the car off too reset (a normal LR thing lol) and the battery is as flat as a pancake. |
Hi Northern and this is the same info I received when researching the alternator failure in my FFRR and again, but I didn’t know this at the time mine failed. Why is it that LRs have such an inordinately high failure rate of alternators when compared to other makes and it is not just the TDV8s. They have always had a reputation for poor alternator usage but as I posted earlier, check out all the threads on the D3UK site and you will see similar on most LR forums. And ric, is is not a case of “Let ME tell you how crap YOUR Land Rover is” They have these problems and thats a fact of life. In the case of alternator failure, I can only go on info I have sourced from forums of other 4x4 makes as there does not appear to be any general documentation relating to this type of electrical failure. If someone knows of car makes with similar issues, please post away but is above, I have only researched this on 4x4 forums. 2007 TDV8 Lux |
Another post on the forum that doesn't sound good and gives the OP here even more wood for his fire.
Hi ebajema, and it appears that LR brake problems are not just limited to the front brake hoses.
I was just going to let this thread die, but really, it never seems to end!!
Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301 ![]() ![]() ![]() |
To be fair that last news story also says Ford had to recall nearly 400k cars for similar problems with doors. |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 ![]() ![]() |
http://www.autonews.com/section/recall
