Home > Technical (L322) > Crimped connector help
johnboyairey
the headache is trimming the wires to feed in at the correct length, ie giving the wires a trim, but not too long, else the outer sheath hangs out the plug etc. you COULD buy a ready made 13 pin converter, and cut it and solder each connection in line further down, (easier) and heat shrink each one, taping up after, your plug is already made up, correctly..
Post #313094 16th Feb 2015 5:53pm
Fish
United Kingdom 2007 Range Rover Vogue TDV8 Rimini Red
Thanks guys,
just thinking about this and I forgot I have a power adaptor to convert 12v to mains so could use the soldering iron on site anyway Embarassed
Post #313232 17th Feb 2015 1:12pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
Alistair wrote:
I just stripped the wire on mine - then filled the whole thing with silicone to help keep moisture out and stop anything working loose over time Thumbs Up
dont forget silicone is a semi-conductor and the one that smells like vinegar is also corrosive to electrical components
Post #313237 17th Feb 2015 1:27pm
Vogue
+1 I have seen the corrosion silicone does - it rusted clean through a steel diesel pipe which was bedded in the stuff! 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #313241 17th Feb 2015 1:42pm
Shocked I didn't know that - I'll keep an eye on it.
Post #313289 17th Feb 2015 4:53pm
