![]() | Home > Maintenance & Mods (L322) > Why is my SC " System too rich " Engine Management |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
There is a TSB from LR on this issue - they recommend the use of BG44K fuel cleaner. I used it on my SC when I had it and it worked a treat. You are only meant to use it once a year though. |
Thanks CG.
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
Should be able to get a can of BG44k at your local Kwikfit Current Fleet:-
Amazon = two days to deliver |
Thank you |
Good idea nicksaab, the local Kwik Fit has it in stock for £20/can.
