Home > Maintenance & Mods (L322) > Best way to remove the FBH fuel pump? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
All fault codes are pointing to the fuel pump as the problem for my FBH, no ticking, so no workie.
31st Jan 2015 10:21am |
Good idea ironhorse, thanks .
31st Jan 2015 10:03pm |
mbmarkyb Member Since: 18 Jan 2015 Location: basingstoke Posts: 22 |
i have no fuel getting to my FBH either and talking to french mike he thinks ecu board but then again i do also have the fault where the fan comes on the FBH if i open a door etc so worth me getting ecu fixed.
6th Feb 2015 7:37pm |
jon3929 Member Since: 01 Jan 2015 Location: Weston Super Mare Posts: 62 |
I'm trying to get to the bottom of why my FBH doesn't fire up too. FF was in for MOT and some service work earlier this week and I asked them to see what codes were generated... none.
6th Feb 2015 8:22pm |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 |
There's not much space up there where it is mounted. I removed ours from underneath working between the prop shaft and exhaust pipe.
6th Feb 2015 8:56pm |
is the electrical connector one of the sealed jobs( so shouldn't be corroded?) also why did you remove the pump was it faulty? I suspect once out it you can put 12 v to it to see if its working?
7th Feb 2015 8:16am |
Thanks for all the tips and advice. Now hopefully it will warm up a bit, I can get it out on the ramps and have a crack at it. Think I may well move it to inside the tank cover, but as mbmarkyb says, first thing is to see if it works, before heading to the pcb repair! .
7th Feb 2015 9:49am |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 |
Let us know how you get on Joe ( with some nice piccies please) |
7th Feb 2015 6:42pm |
If you want to try and see if the pump works before removing it.
8th Feb 2015 12:26am |
Hi thanks for the excellent info Steve,
8th Feb 2015 12:27pm |
May be easier to get at by removing the LF wheel and inner wing? .
8th Feb 2015 12:31pm |
Vaz,
8th Feb 2015 9:39pm |
@jon3939.
8th Feb 2015 10:59pm |
Thanks,
9th Feb 2015 11:24am |
