Home > In Car Electronics (L322) > Sat Nav defaults to Belgium
diggercm
Hi guys,
I was wondering whether this has happened to anyone else.
Each time i start the car and use the navigation, I first need to change the default country from Belgium to the UK.
I have previously deleted all old stored destinations and way points and replaced them with my own, but still they never come back after an engine restart. It's a 57 reg Td3.6
I had it at Brookfields garage this week (mainly for something else) and they did not know how to fix this.
Any ideas from all your experienced minds? Thumbs Up
Cheers
Post #310913 5th Feb 2015 5:48pm
it might be that the sat nav is loosing the signal [uk] from the gps satellites and defaulting to belgium, so it might be your antenna connections are loose or the gps antenna is faulty..... ... - .- -.
Post #310918 5th Feb 2015 6:14pm
Weegie
Sorry, Stan but there are no national GPS signals which is what your post seems to imply.
The signals from the satellites are standard throughout the world resulting in Lat and Long information. It's the receiving equipment that decodes them to map form. John
GAP iiD BT-Sold
Post #310926 5th Feb 2015 6:37pm
to clarify, chap changes default map to UK, drives about and then looses signal from gps satellites, stops and switches off engine....on start up the sat nav realises there is no gps signal so defaults to belgium.. ... - .- -.
Post #310929 5th Feb 2015 6:43pm
diggercm
Almost correct. Sat nav works everytime. It's just that upon each engine start up, I have to change it from Belgium to UK. Plus any stored locations I have entered have disappeared, along previously entered destinations.
Post #310931 5th Feb 2015 6:47pm
weird Confused
have you entered a UK destination after the change of map to the UK so hopefully the nav remembers where you are..
you could also try ejecting the map disc while the nav is set on UK and then stick it back in, only suggesting this as it might force the memory to remember UK. ... - .- -.
Post #310933 5th Feb 2015 6:49pm
diggercm
yep but it still resets itself.
I've taken the cd out a few times and tried to do my own reset but funnily enough the only thing it does store is it's previous owners home address! Do you think it could be linked to which set of keys I use???
I've also tried using the diagnostic tool but that doesn't seem to be able to help.
Post #310935 5th Feb 2015 6:56pm
it might be related to the key memory as i think my other key changes the radio station as well as the seat and steering wheel positions.....
try a different key or press the memory button on the seat when on the UK map [worth a try] ... - .- -.
Post #310936 5th Feb 2015 7:00pm
diggercm
ok thanks. that's worth a shot!
Post #310938 5th Feb 2015 7:01pm
Weegie
If that doesn't work it would be worth trying a reset by disconnecting the battery. Follow the procedure in Wiki. John
GAP iiD BT-Sold
Post #310946 5th Feb 2015 7:29pm
THey all default to Belgium but once you select UK it should stay in the memory until you change it....
30% of the cars I buy are set to Belgium as the owners do not ever use the SAT NAV.
Post #310951 5th Feb 2015 7:35pm
diggercm
i tried the memory function after clearing/deleting the old data and adding new addresses but it still comes up as belgium and remembering the previous owners home and destinations upon restart.
any other ideas guys?
other than disconnecting the battery, which i will try when I get a bit of time (we just had our first child so time is precious!!)
Thanks!
Post #311181 6th Feb 2015 3:30pm
Could be the permanent 12v to the GPS unit, it's doing what it usually does on a battery disconnection every time you switch off... maybe a fuse... can't help further as mines an early one.... Pete
Post #311182 6th Feb 2015 3:38pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
I Haven't got a wiring diagram, but there will be a permanent 12v feed to the unit, even with the ignition 'off', to power the memory so that it remembers your settings. If yo do a battery disconnection, the sat-nav will default to belgum. I imagine that you have lost the permanent 12v feed to the unit, so that every time you turn your ignition off, it loses power and hence defaults to belgium - possibly a fuse? Question 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #311961 10th Feb 2015 2:57pm
mike & the mechanics
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
Mine is doing this and wondered if a cause or what the fault was? Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #370191 3rd Feb 2016 12:48am
