Home > General > Whoi Says the 5.0 isn't economical |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1410 |
31st Jan 2015 5:29pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Down a long hill |
31st Jan 2015 6:06pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1703 |
Nah - I can see Cruise Control is active and so is follow mode... I bet the gap is set to the shortest and you are slip streaming a lorry by about 4 feet... Ash
31st Jan 2015 6:09pm |
also just noticed the yellow marker on your speedo. Whats that? is it a speed limiter (or bong at least) Ash
31st Jan 2015 6:10pm |
Limiter bonger yes... |
31st Jan 2015 6:14pm |
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 |
I can believe that , my car gets between 24-25 on a run and the 5.0 is supposed to be more economical than mine Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
31st Jan 2015 6:24pm |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 |
Tempting.... Graham
31st Jan 2015 6:51pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3752 |
Yes its possible if you drive like a fart 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
31st Jan 2015 7:50pm |
I certainly don't see that kind of average from my TDV8 |
31st Jan 2015 7:57pm |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 |
21Mpg on my 4.4TDV8
31st Jan 2015 8:24pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6731 |
If you get 21 from your 4.4, just imagine how little you'd get with the 5.0 Got - 2017 SDV8 Autobiography in Loire Blue
31st Jan 2015 8:27pm |
Alan i recon about 12 2020 Porsche Panamera Turbo Hybrid (V FAST)
31st Jan 2015 8:30pm |
JackRegan Member Since: 20 Oct 2012 Location: Wirral Posts: 231 |
Just looked at mine, since I've owned it I've done just shy of 9k at an average of 20.7mpg according to the OBC, so likely to be slightly lower in real life.
31st Jan 2015 8:35pm |
Surely you tdv8 guys get more than that on a good run ??? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
31st Jan 2015 8:45pm |
