![]() | Home > General > Driving Range on 3.6 - steady motorway miles |
Welshhope Member Since: 19 Jan 2015 Location: Cymru Posts: 16 ![]() ![]() |
Any advice on the driving range of a 3.6, based on steady (70 to 75mph) motorway miles? Based on average fuel consumption results quoted in a number of posts (anywhere from 25mpg to 30+mph), and given a 105 litre fuel tank; the maths would say between 575 miles to 690 miles to a full tank. Is that realistic?
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
I use my 2005 TD6 every day for a commute to work and back (round trip of 110 miles). I do 550 miles per week at speeds of between 45 and 70 mph on average.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7971 ![]() ![]() ![]() |
In the real world, you never get that close to emptying the tank - I've been into the mid 90's and that was a good few miles past the computer telling me the range was zero |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
If you live anywhere near a mountain you will have no chance of that mileage.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6743 ![]() ![]() ![]() |
400 is about my limit. Got - 2017 SDV8 Autobiography in Loire Blue
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1749 ![]() ![]() ![]() |
Only had mine for a couple of weeks but do 130 a day to work and back. clear motorways is the key to this. The 3.6 seems to be doing around the 28/29 mark if the route is clear at a steady speed.
Thanks for the real-life results. I'm on the M4 almost door to door for 100 miles, so if I plan for low 500s that would be a reasonable target (5 trips before a refill). That's good information for me, and helps me factor fuel into my budget.
I would also try to stick to the speed limit, as you get faster the consumption drops off a cliff. There is nothing that can't be fixed with a hammer😜😜
Harris Member Since: 02 Apr 2013 Location: Northants Posts: 155 ![]() ![]() ![]() |
I do a 50 mile daily commute, mixture of country lanes A roads and city driving and I get 510 to 530 and fill about 90 litres, best I have done on a steady motorway cruise at 70ish is 600 |
Top tips to get good mpg...
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
I have had about 650 miles out of a tank, was steady driving at 60 56 TDV8 Vogue SE
I can't imagine sticking to 60 for 650 mikes! |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
^ I take it you never tried the American Interstate highways in the time if the "double nickel " (55 mph). It's a big country.
