Home > Off Topic - Other Cars > Any one know how to bleed fuel system
Stormin
2003 Range Rover HSE Td6 Epsom Green
We've a 55 plate Nissan primastar which has an intermittent starting problem.
Just fitted a new battery and terminals and it starts most times, a friend has suggested it has air in the fuel line. any ideas how to bleed the system Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #309077 29th Jan 2015 6:17pm
Is it a 2.5dci large van Or a 1.9 small van
If so it could be similar to my master. When mine had a problem starting and also kept cutting out, it was the crank position sensor on the flywheel. Super easy to change and not a pricey part. Get it plugged into something like a snap on diagnostic which can look at live values from it to see if it is giving the correct feed to the ecu. They need to be positioned correctly in relation to the flywheel so they pick up the rotation of the wheel. Worth checking. There is nothing that can't be fixed with a hammer😜😜
Post #309322 30th Jan 2015 7:12pm
