![]() | Home > Maintenance & Mods (L322) > Cheapish oil and filter change. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35504 ![]() ![]() |
much quicker with them using a ramp..
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8683 ![]() ![]() ![]() |
And they have washed and vacced it too...... Which is worth a tenner....
i didnt get a wash |
Thats a bloody good price |
tony66 Member Since: 30 Nov 2014 Location: fife Posts: 92 ![]() ![]() ![]() |
do you have to be under them to do the oil and filter change?
You don't have a choice when it comes to the 4.4TDV8... They have to be vacuumed out |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
yep, and that means main dealer only here! l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
That's daft Craig, how hard would it have been to put a drain plug on it! There is nothing that can't be fixed with a hammer😜😜
i used to be an advocate of the drain plug method-but now if it can be sucked out it will be... |
There is one but its so close to the subframe you can't drain the oil without an 8ft spread of oil EVERYWHERE!!! We tend to suck um out then remove the last bit with the drain bung ![]() ![]() ![]() ![]() ![]() NOT GOOD practice imho ![]() |
a lot of modern cars-pd vag mitsi 4g63[modernish] for example allow more to be sucked out than can be drained due to design...i used to be an advocate of "dropping it" but the vacuum removes most debris-and when in doubt about condition the sump would be coming off anyway to check strainer etc |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 ![]() ![]() ![]() |
Could you not buy one of these and turn it into a DIY job? http://www.ebay.co.uk/itm/Sealey-TP6903-9L...35e3451cd2 405 AB exec seats Baltic and Cirrus 93 RR Classic efi Remember it's easier to get forgiveness than permission! Gone in order: 4.4 TDV8 SE - gone to a good home 93 Classic hard dash Plymouth Blue 03 L322 Oslo Blue 2000 Disco TD5 ES Epsom Green 98 P38 Rioja Red 89 Classic Cairngorm Brown |
i have the 6 litre version-works brill well worth the cash |
[quote="Cam-Tech-Craig"]
Mind me asking where you stick the pipe Craig? Given it's an electronic dipstick (well my 5.0 is and so is Wifey's XF) where do you suck it out from? Dom |
