Home > In Car Electronics (L322) > Sat Nav / Audio problems AGAIN |
Lyndasbottom Member Since: 23 Nov 2014 Location: Devon Posts: 9 |
If you've got the TV tuner unit you can plug its Blue connector into the Satnav Blue socket. they are interchangeable. If it powers up then that gives you some idea of where the fault might be? I don't know which connector provides the power but you could check in Rave. If it's via the White connector this probably won't help. |
21st Jan 2015 6:13pm |
