![]() | Home > Maintenance & Mods (L322) > DPF issue |
Jimmy_75000 Member Since: 06 Jan 2015 Location: London, UK Posts: 27 ![]() ![]() ![]() |
Good morning,
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Hi Jimmy, welcome abord!
Thanks for the info Craig.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16312 ![]() ![]() ![]() |
Thank you very much guys!!! I'll make sure I'll put the high beam on driving in town |
Jimmy, quick note sir... If the DPF goes to orange again? Drive the car as a matter of some urgency, as suggested above! As the light soon turns to RED and more often than not the DPF will need replacing at the dealers! VERY EXPENSIVE!!! |
Replacement DPF, fitted from LR in France 2000 euros.
Cheers guys,
Moi aussi, just figured where you're from then "75000" |
Yep...! But been in london for over 15y now.
How long is a piece of string Jimmy? Mine came on whilst i was not using the car (just moving it around here) and it went to red in 5 or 6 engine starts! So a fine line between orange & red light i think... |
The problem is the DPF coding requires a set rev range for a long period of time |
^^^or do not refit... (for Rest of World specs markets of course, not here) l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
