Home > Maintenance & Mods (L322) > powerful uk door handle covers/others-feedback |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
They need a little help to keep them in place, I used some polyurethane flex adhesive. One because it's what they stick commercial lorry bodies together with, and two, because I had an open tube to hand
6th Jan 2015 12:41pm |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
My Powerful covers just stuck right out of the box.
6th Jan 2015 12:51pm |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
Thanks all (I knew it wasn't silicone sealant for a bath, honest
6th Jan 2015 12:58pm |
tony66 Member Since: 30 Nov 2014 Location: fife Posts: 92 |
i"ve bought a set but not from powerful -cheaper item at £21.99 posted[yes tight scotsman]
6th Jan 2015 2:22pm |
Ryan....
6th Jan 2015 2:30pm |
Si
6th Jan 2015 2:37pm |
Yes. My set came with a keyhole opening cover and a full cover and left it up to me to decide which to fit.
6th Jan 2015 3:09pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6729 |
If you use stuff called "Sikaflex", they'll never come off! Got - 2017 SDV8 Autobiography in Loire Blue
6th Jan 2015 3:18pm |
^^ "Sikaflex" is polyurethane flex adhesive! Only that's the brand name, rather than the product, like Hoover and vacuum cleaner And it will stick to just about anything, they even use it for bonding cars together, like sticking the chassis to the body on a Vauxhall VX 220, I'm pritty certain that's what they use to bond in windscreens
6th Jan 2015 4:46pm |
they look good-hope my chromalikes look as decent as those.. |
6th Jan 2015 5:48pm |
I suppose that the only difference than you'll be likely to notice is the ABS chrome handles are more likely to be warmer to the touch I'd also only use a damp cloth to clean them, as I can't for one moment imagine they will have any more than a few microns of shiny stuff on them. That is the real advantage to solid Stainless Steel handles, you can buff the blemishes out! Yesterday I couldn't spell Engineer... Today I are one!
6th Jan 2015 6:03pm |
Do many people who put colour coded door handles on, also put Powerful's colour coded mirror covers on and do they also colour code the tailgate strip, side vents and bonnet scuttle? |
6th Jan 2015 6:10pm |
I personally can't see the point in putting on handle covers that are painted, especially if your contemplating colour coding the bonnet scuttle, if your going to do that then you might as well save £50 and paint the handles too
6th Jan 2015 6:23pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
I been thinking of fitting these covers on mine for a while now, but not sure which way to go, titanium is preferable ( I think) or body colour ....and yes my bonnet scuttle is colour coded with titanium grill section and all lettering is titanium If it dont work.......burn it!
6th Jan 2015 7:26pm |
