Home > Maintenance & Mods (L322) > Trans oil
kb5
United Kingdom 2004 Range Rover Vogue 4.4 V8 Giverny Green
Trans oil
Hi all,
Does anybody know if Mobil ATF 320 trans oil will be suitable for a 2004 V8 L322 ?? I am thinking over using it.. Question
As I have found 12ltrs of the stuff in my garage ..... also any suggestions as to where to get the gasket kit etc from.. "The most dangerous position in which to sleep is with your feet on your office desk."
Post #26757 30th Aug 2010 7:58am
There are lots and lots and lots of post on this on this and many other forums but here we go once again;
Esso LT 71141 Thumbs Up
this is the only fluid that Land Rover say to use.
http://www.famousfour.co.uk/new_parts/part...-clgb.html
A good place to start looking. 2008 MY Supercharged
Post #26759 30th Aug 2010 8:20am
kb5
Thanks for that reply not possible for me to get that oil where I currently am, hence the Question about the oil I do have ...
Post #26762 30th Aug 2010 8:34am
The transmission is sealed for life but the consensus of opinion is that Land Rover consider the life over once it has broken, ho hum. All I know is only this oil has the properties that the gear box needs .
Is you're playing up ? If not leave well alone until you can get the right oil. 2008 MY Supercharged
Post #26764 30th Aug 2010 8:45am
kb5
To date i've had the high low range motor changed as she kept dropping into Neutral (bit scary on these roads) Ive also changed the rad coolent etc but she is still driving crap i.e once over 50mph she is gutless and on some days getting up the gears is a struggle so was thinking as I had the oil (if it were suitable) I would change it. But now I think I'll wait and see..
I am wondering if the car has gone into limb mode or something but no faults are showing on the dash or up on my hawk eye tester.. I am also wondering if it could be an ecu problem or sensor ...
Fingers crossed my box doesn't go on me as there is no way I can get it fixed here..
Post #26768 30th Aug 2010 10:15am
