Home > Maintenance & Mods (L322) > Air intake
Spartak
United Kingdom 2003 Range Rover Vogue Td6 Barolo Black
Air intake
Can anyone tell me where the air intake is so I can spray some Easy Start into it? Range Rover Vogue 2003
Post #300024 20th Dec 2014 11:55am
cant remember from my td6 days but if you download the WM [link in the wiki] the info will be in there but i suspect that wont help your starting as you have a diesel.. ... - .- -.
Post #300035 20th Dec 2014 1:00pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
As you look into the engine bay, the intake hose goes to the inner wing just behind the right hand side headlight unit.
You can remove it from the body on the engine, mine is secured with a single screw.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #300037 20th Dec 2014 1:03pm
The intake is under the driver side front wing
Post #300091 20th Dec 2014 4:17pm
Spartak
Thanks all found
Post #300092 20th Dec 2014 4:18pm
