Home > Maintenance & Mods (L322) > Battery charge
bazwd
United Kingdom 2006 Range Rover Vogue Td6 Java Black
Battery charge
Almost a year ago to the day I replaced my 2006 Tdi battery with a brand new heavy duty one. First sign of cold weather this year and I'm having to use a starter pack to get the car going. I contacted the suppliers (Tayna) and they tell me that the problem is that I need to charge the battery.
So, is it possible to charge the battery in situ and, if so, do I have to disconnect the leads before doing so as there seem to be conflicting views about this on Google?
Many thanks
Barry
Post #296394 1st Dec 2014 6:48pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
I think a lot of members òn here use the ctek battery charger, which I am looking into buying shortly. There are various ways to hook it up without disconnecting from the car. As I haven't got the 12s tow socket I will probably go for comfort fit under bonnet. There should be a few threads on here if you use the search.
I'm sure someone will be along shortly with other suggestions. Thumbs Up
greg.
Post #296412 1st Dec 2014 7:41pm
Get yourself either a CTek MXS5.0 or MXS7.0 battery charger. Both perfectly capable of charging a battery on a TD6, the MXS7 is just slightly faster. No need to disconnect the battery from the car, you can either connect to the battery, jump posts, thro a permanently live accessory socket or a towbar connection. Thumbs Up
Just a thought, why is your battery down on charge? Is the car not used regularly?
Post #296420 1st Dec 2014 8:09pm
J90
France 2006 Range Rover Vogue Td6 Java Black
do you get a proper 3 pin plug with the CTek or do you have to buy it as an additional item? I only ask because all the pics and user instructions on the web show a two pin continental plug.
Ta, chris Travelling around in circles again.
Post #296590 2nd Dec 2014 7:04pm
If you buy it in the UK you get a 13A 3pin plug as standard.
Post #296596 2nd Dec 2014 7:41pm
netsonic Steve
United Kingdom 2002 Range Rover Vogue Td6 Epsom Green
I was thinking the same........what's happening to mean you need to charge a new battery........
I have a CTek charger which is great, i give the FF a full charge every few months as i don't use it as an every day vehicle. I also put two 1.5w solar chargers from Maplin's in the rear windows with a two into one cable through to the cubby box 12v outlet, most of the cable is hidden, just keeps the battery topped up
Post #296599 2nd Dec 2014 7:46pm
J90
Right that's a CTek on my Xmas list then. Very Happy Travelling around in circles again.
Post #296600 2nd Dec 2014 7:54pm
bazwd
Many thanks for your helpful replies. I will get a charger.
In response to one of your questions, l use the car a lot, usually motorway journeys, but the battery doesn't seem to be holding charge.
Cheers (and HNY)
Baz
Post #302267 1st Jan 2015 10:41pm
Sounds like you have some sort of battery drain issue going on there, either that or a charging issue. With that type of use the battery should be tip top. There is nothing that can't be fixed with a hammer😜😜
Post #302268 1st Jan 2015 10:47pm
What you really need is a voltmeter of the type that plugs into a permanently live power socket so that you can see what is happening to the battery voltage whilst the car is standing and whilst driving.
Post #302288 2nd Jan 2015 10:05am
^ IIDTool can do that! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #302291 2nd Jan 2015 10:49am
bazwd
Many thanks for the additional advice. I think it may well be a drain/not charging issue so will ask for this to be checked when it's in for its next service.
Cheers
Barry
Post #302830 5th Jan 2015 10:55am
