![]() | Home > General > L322 or D3 |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16336 ![]() ![]() ![]() |
Im sorry sir but i think yours might have some issues... All 07my onwards models are a huge step forward from your old FF... I think yours needs a look over |
Chillb Member Since: 25 Jul 2012 Location: Portsmouth Posts: 142 ![]() ![]() ![]() |
That it may however it was LR dealer purchased with LR warranty, really had expected a car that was not only better than my 03 but certainly better than my high miler old D3.
Sorry didn't make that very clear... I own (or did until very recently) both a 2004 D3 & a 2007 FF and i would never want just the D3 over the FFRR... Owned them both side by side and used the D3 for everyday car & the FFRR for nice use... Loved them both but in entirely different ways, the D3 as it was very utilitarian so i was not so OCD about it... The FFRR was just class, in every way better than the D3! Apart from filling it with luggage! |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Suspension parts might need to be replaced. The FFRR should drive very nicely. |
Yes might be, read that set up was the same as the discovery hence similar terrain switch etc so again expected better and quieter. Even cabin noise from the tdv8 is up from the tdv6.
The D3 & FFRR are entirely different underneath sir... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35641 ![]() ![]() |
you're probably thinking of the RRS which has the same underbelly as the discovery Mike.. ... - .- -.
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2617 ![]() ![]() |
Certainly something not right.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8533 ![]() ![]() ![]() |
Get an HPI done on it, must have been a write off or had some serious abuse if you think a D3 is better...
Thought the Range Rover received the Range Rover Sport / LR3's Terrain Response system as well as the redesigned four-wheel drive control panel although appreciate the rest is possibly the original BMW design from 2002, from this assumed ride would be a massive leap from the old BMW system.
Just a quick thought... What tyres are on her? Are they worn at all? If so, are the edges wearing? They do drive a lot differently with the tracking/geometry out and fighting with tyres that are worn... |
Think they are Pirelli's, all look like only a couple of thousand on them, new looking so no wear, thank you. |
I don't know. When you start to see a few things that aren't sorted on a car, I get suspicious about what else isn't sorted that I've missed or can't see. It pays to get a good'un. |
No worries, twas just a thought sir ![]() |
