Home > In Car Electronics (L322) > Some insight (and some questions) about speaker wiring |
J. C. Member Since: 29 Oct 2014 Location: Padova Posts: 38 |
Hello chaps,
29th Nov 2014 4:08pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8334 |
AFAIK there aren't any crossovers, the amp does all the work... have you found the other end of the speaker wire in the door?? Pete
29th Nov 2014 5:31pm |
Outputs...
29th Nov 2014 9:39pm |
Thanks for the pictures Pete.
29th Nov 2014 10:13pm |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 |
Just slightly off topic.
30th Nov 2014 1:10pm |
Just had a look on Rave, there is European, European Export and NAS (North American Spec) All of them show the two levels of sound system as above, all identical....
30th Nov 2014 2:27pm |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
pete
30th Nov 2014 2:36pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7831 |
Ive resisted the temptation to post as I'm not 100% sure how the non DSP systems hang together.....
30th Nov 2014 2:43pm |
Ironhorse, that's an Amp which will have the crossovers built in, or something like that, I can't see it too clearly as I have a pretty awful screen...!!!
30th Nov 2014 2:48pm |
Here is the wiring diagram for the six speaker system, which would normally be fed from the head unit in the dash rather than an amp in the boot......
30th Nov 2014 2:50pm |
If iron horse has uk spec it will have the dsp standard as its a Vogue. That said, mine is not mounted there either, I've got my ULF there. It will be an active system with the unit feeding the speakers and containing the crossovers.
30th Nov 2014 3:00pm |
Are these tweeters any use to you ?
30th Nov 2014 3:44pm |
