![]() | Home > Maintenance & Mods (L322) > Would you ???????????????? |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
^^ I wish I could find the flaw in your argument. I can't. |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
You do know that making hydrogen requires quite a bit of energy? |
It's just some peoople think that because hydrogen is everywhere you've just got to scoop it up and put it in your car. |
Well you're right, it is extremely abundant but needs to be liberated |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 ![]() ![]() |
Yes, I do realise that you need water, and a lot of power. At this moment in time, hydrogen is not really a cost effective gas to produce, I suspect, not that I'm a scientist, it probably takes a kw of power to produce enough hydrogen to make a kw of electricity or less. I say this because, if it took a kw of power to make enough hydrogen to produce 2kw of electricity we would be doing it already.
As per the above posts:
That's General Motors idea, you don't work for them do ya?
To be honest i'd jump at it as i could leave it charging up overnight on the free electric i could generate for it and enjoy topping it up at workplaces where allowed. Also a 400mile range covers quite a bit but it would need to 100% support the quick charging stations that can get near 80% charge in 30mins or less.
FYI my main car runs on SVO all day long with the odd litre of diesel chucked in, as well as old engine oil, fuel filter drain offs...
