Home > Technical (L322) > Remote Heater Keyfob
skavitch
Evening All....
When my 2007MY SE didn't have the above remote, I twisted the dealers arm to aquire one for me.
This is what has turned up.
A. Is this the right one, it looks different to the outline in the manual?
B. Does it need to be programmed?
C. As you may have guessed, it doesn't work!
finally...(and most likely)
D. Am I doing something wrong?
Cheers
Ian Audi A6 3.0 Allroad Quattro
Ducati 1200 Multistrada S
Post #25952 19th Aug 2010 7:52pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
It's the same one as I have for my 2010MY TDv8........................... are you sure your car has Park heat fitted?
You should also be able to set it on a timer function in the touch screen. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #25953 19th Aug 2010 7:54pm
Fox
I think all the diesel FFRR got park heat as standard (HSE not maybe?) from the Facelift in 2005.
Remote is different to mine, but then mine is late '05.
Post #25954 19th Aug 2010 7:57pm
skavitch
I can set it from the screen. (However I've not tried) Embarassed
I suspect a 2010MY one has been ordered...... Audi A6 3.0 Allroad Quattro
Post #25956 19th Aug 2010 7:59pm
Tell them you want a 2010 MDL to go with the keyfob ........ Laughing Laughing
Post #25960 19th Aug 2010 8:16pm
skavitch
Rolling with laughter
Bad enough getting him to cough up for the fob! Audi A6 3.0 Allroad Quattro
Post #25967 19th Aug 2010 8:28pm
Discocuzzy
On my 2004 pre facelift,when i unlock the car with the standard fob, the fuel burning heater fires up, is this normal and would the dealer have programmed the key with this function?
Sorry to slightly hijack the thread Thumbs Up
Post #25996 19th Aug 2010 10:22pm
skavitch
OK, apprentely this needs programmed to the car at the cost of ~0.5 hours labour.
Just need to get it booked in now. Dealer is picking up the tab for this too. Audi A6 3.0 Allroad Quattro
Post #26193 23rd Aug 2010 12:05pm
skavitch
After two hours in Stratstones in Newport, they decided they didn't know how to programme it.
Censored waste of time.... Audi A6 3.0 Allroad Quattro
Post #26263 24th Aug 2010 11:34am
