Home > In Car Electronics (L322) > analog to digital tv swap
Wagon mark
2006 Range Rover Vogue SE Td6 Santorini Black
Can anyone tell me what i need I have a 06 Range Rover Vogue se but tv is just fussy the old analog system I think and want to get it working again by fitting the newer digital system I've looked on the usual sites but loads of different numbers and don't want to buy wrong one can anyone point me in right direction thanks
Post #295189 25th Nov 2014 7:33pm
pm cam-tec Craig, he has the hybrid tuners and will advise accordingly... ... - .- -.
Post #295191 25th Nov 2014 7:37pm
Wagon mark
Thanks for that Stan 👍
Post #295196 25th Nov 2014 7:56pm
Ziggy
Australia
G'Day
I have been playing with the TV in the 08 TDV8 vogue SE today, in
the CCF there is a option to switch from analog to Digital i have done
this but i still don't get any TV stations , i would have thought that with that option there
you should be able to receive digital signal with out adding any extra bits of kit .....am i wrong
Ziggy "Those who cannot remember the past are condemned to repeat it."
George Santayana
Puts away his cloth cap and donkey jacket
Goes and sits in the naughty corner
Post #298136 10th Dec 2014 12:30pm
cant remember where you are ziggy, australialand or here..
if here then confirm you have a hybird unit and then move the FF to a different location and test there.
if down under then see if the digital signals are the correct mpeg2 type.. ... - .- -.
Post #298153 10th Dec 2014 2:29pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
The cars with the touchscreen 05-09 should all ''read'' digital TV automatically.
But, at the same time, those cars only pick up mpeg2. If your country has mpeg-4, bad luck, you're rather stuck... Very Happy
Don't know if the 10-13 can pick up mpeg 4 or not.
The L405 works with the three systems, analogue, mpeg2, mpeg4
Post #298199 10th Dec 2014 4:50pm
UK cars only went digital from 2007 sir Thumbs Up
With the interior facelift Thumbs Up
Post #298262 10th Dec 2014 10:09pm
I can confirm what Craig said Thumbs Up
and that Australia is Mpeg2 so Ziggy you might need to move the car to a better signal area select Aus from the TV options on the touch screen ( I didn't need to change anything in the CCF) and lastly check you have a hybrid tuner but I don't have the different part numbers but the hybrid is slimmer than the old analog . 2008 MY Supercharged
Post #298284 11th Dec 2014 1:51am
Ziggy
Australia
G'Day
Yep in Oz. I had to change everything in the CCF to Oz settings , even the radio didn't work until I changed that
its a 08 model so should be digital so should my car pick up the Oz TV signal.....(our reception is not the best here
even the house TV brakes up when its stormy or cloudy or windy or hot or raining ) in other words TV reception is hopeless )
But had a win with the map CD brought the latest where is CD and works a treat
Zigg "Those who cannot remember the past are condemned to repeat it."
George Santayana
Post #298344 11th Dec 2014 12:27pm
clemenz
Austria 2006 Range Rover Vogue Td6 Zermatt Silver
hello, i live in austria where they will shutdown mpeg2 next year.
is there any solution yet that provides mpeg4?
i was thinking to use the old module and give it analogue signals via an rf modulator?
so you should be able to use any video source.
does anybody tried this yet?
Post #308895 29th Jan 2015 1:31am
J90
France 2006 Range Rover Vogue Td6 Java Black
Gents what does CCF mean? Travelling around in circles again.
Post #308954 29th Jan 2015 10:30am
ccf = car configuration file.... ... - .- -.
Post #308957 29th Jan 2015 10:35am
Knackeredsailor
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
TV analogue to digital
I have the same problem with my 2003 Range Rover Vogue, it has analogue TV.
Is there a plug and play digital replacement?
Mike
Post #308962 29th Jan 2015 10:48am
this is one of many threads re this, found using the search function...hope it helps,
http://www.fullfatrr.com/forum/topic27929....l+tv+tuner ... - .- -.
Post #308963 29th Jan 2015 10:53am
Knackeredsailor
TV Analogue to Digital
Tanks Stan.
Mike
Post #308969 29th Jan 2015 11:04am
