Home > Technical (L322) > non starting primary4.5 bar fuel rail 80 bar ,cars for sale
Page 2 of 3 <123>
trainmanone
England 2002 Range Rover HSE Td6 Oslo Blue
work for transpennine express
if you come into contact with malc sabin say to him its pete who had the omega Thumbs Up have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #295532 27th Nov 2014 8:23pm
Mark L
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
Small world, eh. Wink
Post #295535 27th Nov 2014 8:37pm
trainmanone
sure is lol
still don't fix my heap though lol have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #295537 27th Nov 2014 8:46pm
trainmanone
update..........................
fuel leak from fontish of engine .... high press pump??
only dripping out not under high press so poss a pipe too dark to do any thing now so will have a look tomorrow afternoon,
can spend all day on it sun mon and tues.
if any one wants to give me a hand your more than welcome beer tokens in return
pete have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #295691 28th Nov 2014 4:07pm
trainmanone
great news guys found pipe from filter to high pressure pump on engine to be very lose|||||
taken off pump new clip placed on pipe going to refit tomorrow
so looking good have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #295909 29th Nov 2014 5:06pm
Thumbs Up Lovely when you find it like that Thumbs Up
Post #295943 29th Nov 2014 7:54pm
trainmanone
well pipe refitted and non start air in system been purging with hawkeye for thirty mins !!!!!
pre supply pump reading is 3.5 bar
rail pressure 0.0 bar
when cranking pre supply 2.1-3.4 bar
rail 10.5-50.0 bar
air bubbles can be seen in pipes.
in tank pump and pump under car ordered
any ideas
Post #296069 30th Nov 2014 12:49pm
trainmanone
bump Whistle have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #296817 3rd Dec 2014 5:20pm
trainmanone
latest new in tank pump fitted(motor) new secondary pump fitted (rear wheel arch ) fuel bubbling in pipe past filter(new) only registering 1.1 bar pre supply pressure on hawkey . over half a tank of fuel.
any advice please
need to get running asap as going to trade it in for newer ff
Post #298928 14th Dec 2014 1:00pm
trainmanone
Hi gang latest on this sager
pump in tank replaced and running
pump under car replaced and running
just over half a tank of fuel
can hear pumps priming wen the come to stop can hear from the tank a bubbling noise
still lots of air in fuel line after filter
1.1_1.2 bar on hawkeye
thinking put more fuel in tank ?????
any ideas please as going to trade her in in next week or so and need her running have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #299088 15th Dec 2014 4:03pm
Have you managed to start the vehicle since fitting the new filter?
If not did you fill the filter with fresh diesel or fuel cleaner before fitting?
If not then remove the filter and fill it up manually with diesel until it's full, then replace it and make sure your battery is fully charged, then turn the engine over (might take a few minutes) but it should start eventually
Post #299107 15th Dec 2014 4:53pm
trainmanone
wont start ,yes filled the filter and still no joy ,think I will put a few gallons of fuel then see have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #299109 15th Dec 2014 4:56pm
trainmanone
still no joy with the thing lots of air in fuel pipe after filter hawkeye saying 1.0-1.1 bar and 0.0 in fuel rail.
a a total loss now need help with this as need it running to trade it in have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #299475 17th Dec 2014 2:45pm
You need to find out where it's drawing air into the system
Post #299524 17th Dec 2014 6:34pm
trainmanone
well pevved
latest on this there is no fuel at the filter and non coming through pip to filter ,can hear a gurgling sound but no efing fuel.
if pump in tank was running would you get fuel to filter?
can hear pump running but might be a fubard pump.
any suggestions please have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #299686 18th Dec 2014 4:02pm
Page 2 of 3 <123>
