Home > Maintenance & Mods (L322) > How do I use the interface for Navcoder ?
dan_uk_1984
If you can wire a plug you can join 3 wires....
Post #26248 24th Aug 2010 7:23am
Mounty
Switzerland
I can do that. Sorry. I'm just thick in those things. Daniel
Past:FFRR 2004 Vogue 4.4l bonnatigrey/sand/ burr walnut
Modifications: SC grill (not fixed) SC MY10 sidevents (not fixed), MY10 Letters front and back, clear sidelights , MY10 rear lights (not fixed), MY09 steering wheel trims, new MY09 sterringwheel 19'' seven spoke wheel (not fixed) 19'' MTS (not fixed), 20 '' wheels, doorhandelcovers brunel (not fixed), complete doorhandels (not fixed) burr walnutdoorsouround (not fixed)
Post #26249 24th Aug 2010 7:26am
daveo
hi mate, managed to creep away from the beach..
red is 12+
black is ground
yellow is ibus
the lead as dan said is a micro usb the same as they use on nokias or ps3 controllers
i have a few so if you cant get one i will send you one whaen i get back..
you will need nav coder to run it and its free to down load but will have to pay to activate it
sorry it was a bit rush rush,i posted it on the way to the air port.
dan it looks like i might be able to make the show, i take it you are still going
dave V8 facelift Range Rover Autobiography 22" wheels.
Post #26277 24th Aug 2010 3:37pm
Mounty
Switzerland
Hi Dave. Big Help! Thanks Thumbs Up
Yes still going to the show Exclamation Daniel
Post #26321 25th Aug 2010 7:21am
dan_uk_1984
Which one of us were you talking about!?
Post #26322 25th Aug 2010 7:23am
Mounty
Switzerland
Oh maybe he meant you? I meant Paris. Daniel
Post #26323 25th Aug 2010 7:27am
SteveMFr
Site Sponsor
What's in Paris?
Edit: nevermind - just checked the 'Events'
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #26338 25th Aug 2010 9:04am
Mounty
Switzerland
Steve or any other of your electronic cracks. Do you think that I can fix via Navcoder the problem of putting MY10 rearlights on MY 2004. Idea is to tell the system that are the right bulb in place, instead of LED? Daniel
Post #26779 30th Aug 2010 11:59am
daveo
hi mounty, back off my hols, will pop that lead in the post tomorrow, yes you can turn off the warning for the rear lights with navcoder, done it to my on when fitted a new lcm module to my one, it came from a x5 and it checks a few things the RR dont use.. but befor you start changing any thing make a note of all the ticks and what is set to on and off. dont use the inline load resisters they will get f'ing hot, very hot but if you do make sure you use one that have been tested. i bought a pair of ebay and they got so hot it stuck to my fingers when i touch it, Censored
dave' V8 facelift Range Rover Autobiography 22" wheels.
Post #26829 30th Aug 2010 11:05pm
Mounty
Switzerland
Censored I have to fit resistors and where and what else? Oh for what have I left myself in? I even don't know what are inline resistors. Steve Exclamation you want plenty of beer!!!!! Daniel
Post #26832 31st Aug 2010 7:10am
Mounty
Switzerland
SteveMFr wrote:
If all that doesn't work you'll need to buy me a large number of beers and I'll come to Basel and hook it up for you. Razz
Steve: How about a trip to Basel? Daniel
Post #26841 31st Aug 2010 10:29am
SteveMFr
Site Sponsor
Let's see if we can't get you fixed up first.
The in line resistors are just to increase the impedance (resistance) of the LED's to what a bulb normally has. The LCM checks for this to make sure the bulbs are still there and functioning. A burnt out or missing bulb has infinite resistance and a short in the circuit (say after an accident where the wires are crushed by crumpled metal) would mean no resistance - or very little as in the case of the LED's.
So your 2 options are:
- Fit the lights with in line resistors to the same value as the light bulbs you've replaced with LED's (some just mount the old lights in line with the new inside the car - not very elegant but functional)
- re-program the LCM so that it does not perform a light check on the taillights - elegant and simple
Re-read Daveo's instructions carefully, read the Reseler website again and go to it! It's only 3 wires and USB. It should be nice and easy!
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #27057 2nd Sep 2010 8:50am
Mounty
Switzerland
I take option 2 Smile Thanks Steve. Daniel
Post #27064 2nd Sep 2010 10:17am
