Worth getting it checked again, I got f1 autocentre to do mine in burton on Trent, set it up on the hawkeye and adjusted it for front toe as that was all that needed doing (had just had new track rod ends) It showed as a bit out on one of the front camber settings which needs a special too to set, so we left it.
I then got Kwik fit to check it a couple of days later, and to be honest they got pretty much the same readings. One thing to remember is that the car needs settling on its suspension, minimum up and down on the suspension, preferably it needs putting into tight tolerance mode prior to adjusting.
I have since had the rest of the front bushes/arms done and all is now in the green.
Inner edge wear is quite often toe related and this is the most common variable which needs adjusting but could be caused by bad camber, but if your bushes are all ok then this is unlikely to be out much. There is nothing that can't be fixed with a hammer😜😜
