Home > Maintenance & Mods (L322) > rear dampers on 3.6 tdv8 2007 |
Watty Member Since: 02 Oct 2013 Location: Kirkintilloch Posts: 56 |
Do not need help anymore, took a while but I eventually found the top of the dampers after having removed more of the interior than needed. Will supply pictures shortly actually very easy to replace both dampers 07 Vogue SE Java Black 3.6 TDV8
29th Oct 2014 10:11pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Pics would be appreciated.
9th Nov 2014 12:04pm |
I will put pictures on later today. Quite a coincidence I am speaking to my daughter on Skype she stays in Brisbane 07 Vogue SE Java Black 3.6 TDV8
9th Nov 2014 12:23pm |
Yes both shockers are the same 07 Vogue SE Java Black 3.6 TDV8 Black Leather heated/ cooled seats Piano black trim deployable side steps L405 Autiobiography 2017 Santorini Black with black pack 13 L405 4.4 Autobiography |
9th Nov 2014 12:24pm |
I needed to change the rear dampers on my rr, after obtaining advice from a so called expert I started to strip out both sides of the boot interior after about 2 hours I found that this was a waste of time. as I still could not get to the top of the strut.
9th Nov 2014 6:12pm |
Isn't it amazing how things happen in clusters I have a weeping near side rear damper and have just ordered two from the UK , I was going to ask how to do this and along comes this post 2008 MY Supercharged
10th Nov 2014 12:03am |
Mark L Member Since: 29 Oct 2014 Location: Tamworth Posts: 121 |
I also need a pair of rear shock absorbers... |
10th Nov 2014 12:40am |
It's all happening here with G20. hopefully not as much action as happened in London. |
10th Nov 2014 12:38pm |
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 313 |
What is the likely price to fit two new rear shock absorbers? (supplementary question - are they different parts to the airbag spring units, or integral?). I had an MOT advisory of an oil weep on one of my rear shocks, so am interested.
10th Nov 2014 1:09pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Rear shocks are separate from air bags, if you do it yourself, do not let the suspension wishbone fully off support when removing the shock, this will put the full pressure on the airbag and you could damage it, the shock controls the amount of drop on the suspension so taking it off means the airbag can burst, the book says you should depressurise the suspension on the corner your doing but this isn't really necessary if your careful....
10th Nov 2014 3:26pm |
Thanks, that's helpful. Which brand should I use when replacing (or which to avoid)?
10th Nov 2014 3:33pm |
Originals are Bilstein, have a look here....
10th Nov 2014 4:58pm |
Haylands - top man, thank you.
10th Nov 2014 5:23pm |
Even cheeper;
11th Nov 2014 2:02am |
