Home > Technical (L322) > Air con stopped working again
Swiftman
Scotland 2006 Range Rover Vogue SE Td6 Zermatt Silver
Had aircon recharged. May 2013 worked ok all summer. Recharged again may 2014 no fault showed up worked ok till last week no cold air must have a very small leak can't decide whether to leave till next summer & get it recharged or get it repaired suspect condenser may have small leak. Takes 3 months to lose gas pressure . Any ideas or advice welcome L322 td6. 2006 Thumbs Up
Post #287936 21st Oct 2014 2:05pm
dingg1
find out where the leak is and replace that part
as you have inferred most likely condenser , but may be somewhere else as well.
aircon people can inject a dye to trace leaks
Post #287946 21st Oct 2014 2:48pm
the condenser is right at the front and easily gets hit by stones and road debris.. ... - .- -.
Post #287957 21st Oct 2014 3:39pm
Lee Marsh
England 2006 Range Rover Vogue Td6 Zambezi Silver
Where abouts Stan? Any part numbers mate if poss, '06 Vogue Td6
Post #479028 21st May 2018 11:47am
the part numbers can be obtained from the russian microcat.. ... - .- -.
Post #479030 21st May 2018 11:51am
Lee Marsh
Oh right, nice, whoever that is.
Jaguar Land Rover quoted for seemingly a whole radiator when enquiried 🤔 There is a part # can see through front grill reads PDA000101.
Seems common fault, is it the whole aircon rad that needs changing and is the condensor in fact the aircon rad. As others have talked of some valve type part.
Post #479044 21st May 2018 2:16pm
Lee Marsh
Ok I’m with you Wink
Cheers
Post #479045 21st May 2018 2:23pm
fisha
Lee that part number you have is for the electric fan on the front. I think the ac condenser rad is jrw00020 or jrw00024.
The best place I’ve used for this sort of stuff is glasgow radiator or g&m radiator.
As an example I got a new coolant radiator from them for my 4.2 a while back for about £130 ....it was stamped and labelled BEHR and was an original part. Couldn’t come close that price anywhere else online (I.e. £300) . So may be worth a try. V8 or else ...
Post #479070 21st May 2018 7:24pm
Rewmer
I got mine from an aircon parts specialist. Can’t reme who now but it was about £70 all in No7 - 2003 V8 Vogue
Post #479083 21st May 2018 8:49pm
