![]() | Home > Technical (L322) > gearbox sticking in gear |
MARKS2RR Member Since: 29 Aug 2014 Location: Lancashire Posts: 12 ![]() ![]() ![]() |
just accelerated getting up to speed on the motorway, gears seamed slow to change, revs got to about 2100 and slowly
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
That sounds as if you've got some water in your fuel system, was the tank on low? And can you get it to do it again?
Just noticed this thread it would seam to be simular, but constant problem, worth a read / check
i have half a tank of fuel, i have been using shells more expensive diesel from a shell garage on a main road.
dealers had car for two days, couldn't find problem with gearbox.
You'll probably find that the engine smoke problem has caused the gearbox to hold the gear change, and there is, fingers crossed, nothing up with the box. Just not enough engine to make it change! The gearbox is governed by the speed that the car is going, and effort that the engine uses to maintain that gear. If you have a loss of power, but you've still got the same throttle setting, or increasing, the gearbox thinks your going up a hill (for example) and holds the gear change longer. Power loss can also show up as a refusal to 'kick down' under heavy acceleration.
i was thinking the same, if they sort the smoke issue that gearbox fault will disappear, fingers crossed.
