![]() | Home > Technical (L322) > Brembos? |
otto-mate,
otto-mate Member Since: 07 Oct 2014 Location: Northern Ireland Posts: 126 ![]() ![]() |
Thanks pld118. I've just sold my X5 and I'm in the research/looking phase at the moment, my profile is set to 'not an owner'. |
Advanced Factors Site Sponsor Member Since: 31 May 2013 Location: Southampton Posts: 198 ![]() ![]() |
Have a look through the braking section of my website, you will find the info you are looking for by model year/engine type
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1789 ![]() ![]() |
Brembo's were available on all SC models from 2006, and all TDV8s from 2007
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8689 ![]() ![]() ![]() |
They were fitted to all 2006 -> 2009 cars, 4.2sc and tdv8. They were discontinued on the 2010 facelift year 3.6tdv8's but continued on the s/c and were reintroduced to the diesels with the 4.4tdv8 which have the 6 pot calipers. I think the 5.0sc has the 6 pots too but not sure when they were introduced though I suspect at 2010 facelift. There is nothing that can't be fixed with a hammer😜😜
As above but for clarity, the 2009 3.6 TDV8 facelift was when they ditched the Brembo's and then re-introduced them (in 6 pot guise) on the 2011 4.4 TDV8 |
That's what I meant... |
sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286 ![]() ![]() ![]() |
I fitted brembos to my disco and it was much better, ive brought a ffrr on the change over plate 59.
I have not checked but... 4 pot Brembos have a smaller mounting bolt than the 6 pots so, NO you cannot put the 6 pot on a 4 pot hub (if that makes sense?) so, you would need to check the size/diameter of the mounting bolt hole through the hub on your car to tell if it would take the earlier 4 pot of later/larger 6 pots |
Thanks, i just meant that if all the pre 2009 had brembos, and then for 1 year they stopped and then started again after 2010, was there and interim part number for the brakes, or were there earlier tdv8s without brembos?
nobbyclark Member Since: 16 Sep 2014 Location: Cumbria Posts: 131 ![]() ![]() |
Why did they ditch the Brembo brakes on the 3.6 TDV8? Cost? Reliability? Something else? My TDV8 obviously has non-Brembo brakes as it was built in Jan 2010, but it could certainly do with them as whatever it is fitted with are not really up to the job. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35516 ![]() ![]() |
could have been a cost or supply problem.. ... - .- -.
