Home > Technical (L322) > Suspension Fault Max Speed 30mph and HDS INACTIVE warnings
tato
Argentina 2006 Range Rover HSE 4.4 V8 Barolo Black
Hi guys,
I have serious problems with the suspension on my 2006 HSE and would appreciate if I could pick the knowledgeable brains of the members on this website to try and find a solution.
These problems have been going on for over a month but unfortunately neither the garage where I purchased the car have been able to fix them.
These issues occur on short trips around town, the car would show the "Suspension Fault" warning and HDS Inactive warning followed by the rear and front suspension totally deflating. By pulling in to the side of the motorway on a few occasions and turning the car off for a while I managed to re-inflate the suspension.
Thanks
Post #284190 2nd Oct 2014 10:58pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Impossible to say.......
First guess is battery or alternator but guess work is a long, expensive road! It needs plugging into diagnostics to be sure. 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #284193 2nd Oct 2014 11:12pm
tato
Thanks Skot Big Cry
Post #284194 2nd Oct 2014 11:18pm
SKOT
Keep an open mind. Once you know the fault code(s) from diagnostics there is every chance it's a simple, easy fix! Thumbs Up 2006 4.2 SC
Post #284195 2nd Oct 2014 11:23pm
mavester
United Kingdom 2007 Range Rover Vogue SE TDV8 Stornoway Grey
Mine did this for a while and then it stopped. Weird.
I think mine was caused by a slow puncture on the left rear wheel. Once that was sorted out, and the tyre inflated properly, it stopped. Probably/Possibly a red herring but worth checking all the same.
Post #284247 3rd Oct 2014 10:45am
rover1
I had the exact same problem. I found no fault code.
My thought was that I had driven off to quick before the car had self levelled.
I have let it level off if required and never had it happen since.
just my thoughts.
Post #284569 6th Oct 2014 12:10am
salb
United Kingdom 2007 Range Rover Vogue SE Supercharged Santorini Black
IID TOOL purchase a must..............
Then its a slow and puzzling game of working through the faults
worked for me .
sal RANGE ROVER OVERFINCHED 4.2 S/C
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
STAINLESS STEEL EXHAUST O/F
CARBON FIBRE WING MIRRORS & A PILLARS & CENTRE CONSOLE
Post #284573 6th Oct 2014 6:29am
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I get this very occasionally if moving off too fast after start up and height at access. Turn off & on again and fault clears. Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #284630 6th Oct 2014 1:53pm
aclr8r
United Kingdom 2009 Range Rover Westminster TDV8 Santorini Black
Could be the steering angle sensor?
Had mine do similar normally about 10-15mins into driving.
Need to get codes to confirm if the sensor is shot!! If you don't know what you're doing - do it quickly!
Post #286003 12th Oct 2014 11:39am
Could be caused by a faulty ABS sensor in one the rear wheel hubs
Post #286007 12th Oct 2014 12:11pm
