Home > Technical (L322) > Td6 Still Won;t start
Page 5 of 5 <12345
theanswers
Ireland
Hello Stewart,
If the injectors are ok it can be a number of other sensors causing the problem. First my injectors failed, then shortly later the injector pump or rather a valve on it.
That was causing my problem in this case. The valve prevented the pressure building the rail. Did you check cranking pressure at the rail? Does yours start with easy start?
If you need a injector pump, look out for a e39 530d BMW - they are great for donar parts.
Post #324907 29th Apr 2015 8:22am
Stuart8185
2007 Range Rover Vogue SE Td6 Orkney Grey
Firstly thank you very much for the reply Thumbs Up
The fuel pressure regulator valve Ontop of the pump has been replaced
Along with the low pressure fuel pump
That got rid of my codes for fuel rsil pressure short circuit to ground
I know have no faults and the car will not start on easy start
The injectors never receive the voltage from the Ecu
The Ecu has also been tested
I always had fuel pressure
Although The maxi das 708 and the snap on verso are good Range Rover don't part with much info to test plan
I know think I may have an issue with either can bus, key or there a outs
Any suggestions
My mate called me last night in regards to a relay inside a alarm Ecu at the rear of the car
All I can see in there is the part tonic Ecu fuse board and tow bar Ecu
Post #324911 29th Apr 2015 8:52am
Page 5 of 5 <12345
