![]() | Home > Technical (L322) > Td6 Still Won;t start |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 ![]() ![]() |
Hey. I did this. No liquid emerges from the injector whilst turning over. So either; injector wiring is faulty (Don't think so), a sensor is faulty and or the HP fuel pump has failed? I'm not sure which one to lead towards? Two warnings are being detected on the handheld; Boost Pressure Sensor and Low Pressure when starting. Just checked various fuses etc. all looks good. So to round up; - No fuel being sprayed from injector during turnover (Starting) - High Pressure KPA @ 1000 when turning over. - Low Pressure KPA @ 320 when priming. - Seems ok. - Injectors recently reconditioned - New Fuel Pumps (Rear Wheel) Tank one Seems good. (Car drives fine when started. Could it be an immobiliser issue? |
Don't mean to point out the obvious but the plugs are used when the engine wants |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
Will, he's talking about the injectors not the glow plugs. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1789 ![]() ![]() |
It's not immobiliser. Or glow plugs...
I was replying to Johns |
What pressure do you get when running? I've seen from 30k to 130k in pressure readings on mine. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Ok, sorry. ![]() |
So you should be young man 😜😜 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Hey - Sorry no I did not test all the injectors. Perhaps I should! The rail sensor is reading 1000kpa (turning over). I'm leaning towards the High Pressure Fuel Pump. Before we removed the injectors - it started on the easy start. Now no such luck. It will not fire with easy start. I'm really unsure what more tests I can do!! No leaks anywhere, there is fuel at the rail and at the leak off pipes. Plenty of it. The Injector hardly could be faulty they are just backed from being reconditioned/ tested for the second time (uncle). |
The leak off test is a red herring when the injectors aren't firing as they need to bleed all fuel sent to them away as its not being used when it gets above their set pressure.
Hey Guys.
Before you go to that extreme swap the tail pressure sensor just incase |
I swapped the rail pressure sensor.
Pump it is! Keep the old one though as they can be easily stripped and refurbished though generally better to just sell it to a refurbishment place |
