![]() | Home > Technical (L322) > Td6 Still Won;t start |
Ok currently the low pressure side is;
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1789 ![]() ![]() |
Low pressure is fine ![]() High pressure is too low. This can be a regulator valve issue, HPFP, fuel leak, or a faulty injector A leak off test takes 20 minutes to do, and costs nothing. That would be my starting point ![]() |
Regulator valve is on the back of the HPFP, and controls the high side fuel pressure |
Did you try it across all of the electrical connectors as that could point to one of the connectors being duff?
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
Yes, mine started (just) at -8.5°c with five completely f*ked glow plugs and one dodgy one. |
Also it may not be the plugs themselves but the glow plug relay. I've seen this fault log on mine a few times but then go away when I want to look at it in depth |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
It's unlikely to be glow plug or glow plug relay related. .
It wont be glow plug related. The fault lies between the LPFP and fuel being injected |
True but it's best to fix it when in there as they are a butt wipe to get to so worth the time doing it while testing bits in there |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 ![]() ![]() |
It looks like someone was at it before as one of the glow plugs is literally sheered and therefore most certainly not working. so will have to skip the glow plugs for now. And Yes- it is the relay according the computer/ The lights does not come up on the dash.
Here's the wheeler dealers episode where he sorts out the injector loom.
It's ok I have spare injectors here too.
You need,
Hmm. Bit difficult to diagnose with no diagnostics. |
