Home > Wheels & Tyres > Stupid Question Alert!!!
Vorbis
United Kingdom 2007 Range Rover Vogue SE TDV8 Santorini Black
Ok, so I've just been and had a new rear offside tyre fitted and had all four wheels realligned at the same time (they were all going in different directions apparently) On the drive home I noticed that to go in a straight line I have to turn the steering wheel very slightly to the right. No idea as to whether this is normal or whether it was doing it before (if it was I hadn't noticed) Is there something wrong or am I being a bit dense?
Post #285027 8th Oct 2014 12:43pm
road camber going towards the kerb would cause that...try a drive on a dual carriageway or motorway. ... - .- -.
Post #285034 8th Oct 2014 12:53pm
Vorbis
That's where I noticed it. Its not much but definitely have to have the wheel slightly right to compensate for the camber
Post #285039 8th Oct 2014 12:57pm
in theory ,if you drive on the continent then you would have to turn the steering slightly left to compensate for their camber.. ... - .- -.
Post #285042 8th Oct 2014 1:05pm
Vorbis
I thought the steering was supposed to be set to compensate?
Post #285045 8th Oct 2014 1:14pm
but if you compensated for our camber then it would be out further over in europe..
as said, try it on the motorway and it should track straight.. ... - .- -.
Post #285047 8th Oct 2014 1:16pm
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
If your tyres have scrubbed a bit then give them 50 miles or so to settle in Thumbs Up
Post #285050 8th Oct 2014 1:20pm
Vorbis
I tried it on the A12 and that's where I noticed it. No motorways around here Laughing
Post #285054 8th Oct 2014 1:49pm
Laughing ... - .- -.
Post #285055 8th Oct 2014 1:52pm
Vorbis wrote:
No motorways civilisation around here
Post #285056 8th Oct 2014 1:57pm
Vorbis
That's the way I like it, I know its unusual to see a range rover actually used in the countryside Laughing anyway I called the tire centre and they said it shouldn't be doing it so I need to take it back in Rolling Eyes
Post #285103 8th Oct 2014 6:03pm
