Home > Wheels & Tyres > Tyre inflator???
mjdronfield
I see all that with a £25 buy it now. Just seems a little cheap.
Could buy it and even if you only get the accessory kit it's not too bad.
Though to be fair, it does look like it's everything.
The kit is normally about that price on its own.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #284620 6th Oct 2014 1:10pm
^bit OTT for inflating a tyre Shocked Got - 2017 SDV8 Autobiography in Loire Blue
Post #284621 6th Oct 2014 1:11pm
ebajema
I had a small compressor on 240Volt great for using the air wrench (I'm missing that here as I gave the compressor away) on motorbike sprockets (I just did the chain and sprockets of the B-King and really miss my compressor).
If you can find a cheap one for a decent price, I suggest to get it as they are quite handy to have around. The 12 Volt compressors are great for topping up but may overheat after a while (well the one in Nigeria did). The big compressor can of course last a lot longer.
It all depends on what you want to use it for. The small 12V is handy while travelling and you need to top up the tyres (in Holland and Germany I noticed that you have to pay, same as in Nigeria so the small 12 V pays itself back in no time).
If you also want to use it (sometimes) for cleaning, tool driving, the bigger compressors are great. Compressed air is still one of the best ways to get things cleaned out once the caked stuff is loose. MY 2010 5.0 SC Galway green and sand interior!!
Post #284623 6th Oct 2014 1:15pm
mjdronfield
Laughing
I know. But it's what I use as I don't have to start the car up and drive to a petrol station and use their line that has been thrown about by everyone and is prob not calibrated properly.
My 12v smaller one needs silly amps and is heavy on the battery without the engine running. Don't want to start the car from cold just to check tyres.
Do you chaps use the one at garages mostly then ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #284624 6th Oct 2014 1:15pm
the £25 cobra on ebay is priced via the drop down menu, £25 for the tools and £75 for the compressor.. ... - .- -.
Post #284627 6th Oct 2014 1:47pm
for checking tyre pressures i use one of these, @ just under £16 delivered,
http://www.ebay.co.uk/itm/380984787743?_tr...EBIDX%3AIT
luckily i have two mains compressors to adjust the pressures but i also have a 12v jobby in the back of the FF just in case i need to inflate away from home.. ... - .- -.
Post #284629 6th Oct 2014 1:50pm
mjdronfield
That looks posh Stan.
Does it do fancy stuff ? What's the buttons for ? To change units ?
I use a Halfrauds digital one for checking. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #284631 6th Oct 2014 1:55pm
its a backlit digital with functions for psi,bar etc.. ... - .- -.
Post #284632 6th Oct 2014 1:57pm
Sandyt
I bought one of these
http://www.ebay.co.uk/itm/371102571440?_tr...EBIDX%3AIT
I have a few cars to do not just the FF so it makes sense will probably put in a fixed connection point in the drive and can use the air for blowing out crap when stripping down components and cheap enough
Thumbs Up Thumbs Up
Post #284670 6th Oct 2014 6:19pm
nice bit of kit that is Thumbs Up ... - .- -.
Post #284674 6th Oct 2014 6:24pm
mjdronfield
That will do the job.
I have had no issues with my 2hp version.
I also got a free air staple gun, plus the free 5pc accessory kit, which when I costed it up, looked like the compressor cost me just over £40. Well happy with it.
You never get free kit free of course !
I use the spare compressed air in it after I've done my tyres to clean the dust out my Dyson vacuum...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #284677 6th Oct 2014 6:31pm
