Home > Technical (L322) > Battery Management System????
Rangie4fun
Austria 2013 Range Rover Autobiography TDV6 Barolo Black
Had changed my battery, but still have problems with dreaded "HDC inactive" message after a few days. I don't have any significant battery drain (about 20 mA), replaced alternator and also FSR. Aaaaaargghhhh Evil or Very Mad Big Cry
So today went to a battery specialist and he told me that my car had a Battery Management System (BMS) which might be the cause of my problems (battery not fully charged, while battery is OK). He said that with a battery replacement the new battery should be programmed by the dealer to the ECU. Question:
1. Is a FF Td6 MY 2005 equipped with a BMS?
2. Has anyone heard of, or experience with reprogramming the battery?
3. Can I do this with the IID Tool?
Any other suggestions most welcome!!!!! Bow down Bow down
Post #282477 23rd Sep 2014 4:31pm
Rangie4fun
Had the battery connected to the charger overnight and battery was fully and deeply charged. Had the FBH running twice for half an hour (it takes initailly 22A and after 5 minutes constantly another 17A). After that cycle I had still 12.35V in the battery.
Makes me think that the battery indeed wasn't fully charged. But how come Question Question Question
Any suggestions about the BMS? Is my car equipped with that? I couldn't find anything about it in the Rave.
Any help much appreciated Bow down
Post #282657 24th Sep 2014 3:52pm
iphs
England 2003 Range Rover Vogue Td6 Buckingham Blue
Sorry I don't have an answer for you about a BMS. I am surprised that one of the more knowledgable members have not come back to you as yet.
If it helps, I find that if I am not using the FF for a few days, I have to connect the battery charger on a trickle charge. Even with a brand new battery.
I find it amazing that systems continue to operate for about 20 minutes after switching the ignition off. Then if you unlock the car to get something, various systems become active and again run for about 20 minutes. So unlock and lock your vehicle several times without starting and giving it a run and you soon end up with a flat battery Rolling Eyes
Post #282661 24th Sep 2014 4:48pm
Rangie4fun
Yes, IPHS this is a silly configuration that each time it wakes up it takes some 20 minutes and consuming 7A .
Still my problem is why the alternator doesn't fully charge the battery Question
Hope one of the "electrical" guys comes up soon with some help Mr. Green
Post #282667 24th Sep 2014 5:20pm
mavester
I'm not an expert on this but I think BMWs of that vintage have a battery management system that needs a reset when you replace a battery (the E65 7 series has this). If you don't reset it then the car doesn't know it has a new battery and treats the new one like the old one and can cause problems. I'm not sure it has an effect so quickly though.
I'm having battery issues at the moment so this topic is of particular interest to me. In my case I'm getting Terrain warnings related to low voltage (I think), even on a new battery.
Post #282808 25th Sep 2014 3:36pm
i had a td6 and during my ownership i had two batterys and neither time was anything reset.. ... - .- -.
Post #282822 25th Sep 2014 5:12pm
Same as Stan , Red herring . 2008 MY Supercharged
Post #282902 26th Sep 2014 3:57am
