Home > Technical (L322) > Heater-trouble-Warm on idle, cold driving. 140 cap to blame? |
Have you downloaded the workshop manual of your model yet ?? Have a look at the cooling system.
20th Oct 2014 1:06pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
There is an auxillary electric heater pump in the highline system (independent temp for driver and passenger)
20th Oct 2014 3:04pm |
MariusRR Member Since: 19 Mar 2013 Location: Oslo Posts: 98 |
Thank you!
20th Oct 2014 7:07pm |
Might be blocked heater pipe to/from the pump, or as it gets hot it collapses, worth having a good rummage around all the pipes to see what you can see, take them off if you can and stick a hosepipe through it... Or
20th Oct 2014 7:30pm |
THis is starting to drive me quite insane.
20th Oct 2014 10:48pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Blimey. I've had the FFRR 5 years and I didn't know about the rest heating function! |
21st Oct 2014 4:02pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
I won't point out its in the manual.....
21st Oct 2014 5:25pm |
so, I have to things i can try. Flushing the heater matrix. Anyone have a good tip how to?
21st Oct 2014 8:06pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8513 |
Haven't read the whole post.... So my bad if it's already been mentioned.
21st Oct 2014 9:09pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
I agree with the monkey above . If you standing at the front of the engine bay looking, the 2 valves sit upright against the right hand wing as you look into the engine. You'll see the coolant pipes from the bulkhead and do a 180deg turn back into the valves. These sit quite close to the exhaust manifolds and I found on mine that the wires and connectors not he valves felt like they were were brittle / slightly corroded. I unplugged the connectors, gave all the contacts a good clean, and this seemed to sort out some poor heat I was having.
22nd Oct 2014 10:56am |
I took the valve out earlier this year. but the torx were corroded. So i sort of gave up. Now I am freezing to death so I will give it another try. Must just find out how to get the broken torx of and where I can get new ones if i succed getting them of.
22nd Oct 2014 8:43pm |
