Home > Technical (L322) > Fuel Burning Heater - Excessive Smoke?? |
Larry Member Since: 03 Dec 2008 Location: East Midlands Posts: 262 |
New to the site and to Range Rovers, so hoping someone can help.
3rd Dec 2008 8:45am |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6370 |
These can be a problem, but rarely, sounds like you are unlucky.
3rd Dec 2008 11:50am |
Cheers for that. From the sounds of it I may have a problem. It's been making the smoke screen for 2 weeks now, so it should have died down if it does that for the first couple of times in winter. The smoke is preceeded by an overpowering smell of diesel (I usually pray that the traffic will start moving at this point so i can leave the envitable smoke screen behind! )
3rd Dec 2008 12:17pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
hi i use mine each morning and i havnt noticed any smoke but i have heard that the exhaust on them will leak a bit for the first few times of use if it hasnt been used for a long period and it has to reseal itself i could be wrong and i probly am but if it is that bad maybe dont use it and get it checked out by a dealer at the end of the day youve got diesel going into a burner thats possibly not working correctly and in that case uve got the pottential of a serius fire issue in the worse case scenario so for the sake of at most £100 getting it checked out youll have peace of mind and a nice warm FFRR onto no6 Range Rover
6th Dec 2008 1:09pm |
Slightly off topic but I have noticed that since I had a flat battery a few months back, mine finds it much harder to start if I use the pre heater, the longer its on, the harder it is to start. A sure sign my battery is not what it was. Discovery 4 HSE
8th Dec 2008 9:44am |
In a conversation with a Land Rover technician about FBH's he advised that it was a bad idea to use the timer/key fob switch on for the FBH (ie. without the engine running) as it kills batteries. His opinion was not to use it full stop.
8th Dec 2008 9:48am |
Full fat not diet Member Since: 16 Nov 2008 Location: Herts Posts: 1209 |
Guys, Sorry to sound an idiot but is the FBH, the thing what warms up the car before you get in it in the morning. I remember hearing that this was possible on a ffrr but have never checked to see if mine has it. I have a 2004 TD6 Vogue and i dont think i have this but perhaps someone can confirm and if so how i use it etc. |
8th Dec 2008 10:11am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3747 |
Is is to my knowledge only available on the Diesel vehicles, standard on Vogue but not sure from which MY.
8th Dec 2008 3:16pm |
Thanks Vogue for the reply. Mine is the Diesel Vogue (2004) but i dont have an additional key fob. It sounds great and i hope i have it. I will look through the handbook and Sat Nav Controls to see. If anyone knows which model year it was available for then please let me know |
8th Dec 2008 3:54pm |
I think some Vogue MY's had the heater but no remote - this had to be purchased separately. 2006 on it was all standard. The FBH was/is available as an aftermarket kit as well.
8th Dec 2008 5:19pm |
I will have a read through the manual to see if i have the heater etc although i am fairly confident there is no remote fitted as Car has been in Family since brand new and this wasn't mentioned by Bro in law as an extra.
8th Dec 2008 6:38pm |
No remote with mine or the option on the touch screen to set the timer etc.
9th Dec 2008 9:06am |
If your battery is ok it has no impact, never had an issue all last winter but think my battery is damaged from running totally flat once. Discovery 4 HSE
9th Dec 2008 9:31am |
