Home > Technical (L322) > Another 'HDC inactive & Air Susp. Inactive' thread....
Mustard
As luck would have it a few hours before departing on a much needed easter break I get bong bong bong flashy flashy dashy Crying or Very sad
My local 4x4 specialist offered me a fault code read & clear but thats all he could manage at that time, due to being full of work, so I got it over to them pronto. Funny that when they started it to drive it into the workshop it didn't bong bong bong, always the way. The mechanic plugged in the fault code reader and he said there were all sorts of errors that were due to the battery being disconnected. (I had it changed to new Bosch 6 months ago). He said it looked like the main problem was an error from 'the steering angle sensor' so he re calibrated it, cleared all faults and set me on my way.
Couple of hours later before loading for departure bong bong bong etc.....Great Mad
The compressor sounds different than normal (I think), the ride height is locked to 'normal', the motor is sitting level and able to maintain 'normal' height as it dips slightly and then raises itself again, so I decided to push on and drive the 150 miles needed to get me to where I needed to be. I didn't drive over 50 mph with all the lights and warnings flashing away at me but it managed the journey with no problem Smile
My question here is am I damaging it by driving it when in this state ?
Should I keep the driving down to a minimum / certain speed ?
If it drops on a corner or entirely onto the bump stops what should I do ?
I do have RAC cover but all they could do would be take me home and my easter break would go down the toilet Big Cry
Post #254850 17th Apr 2014 12:26pm
Should be OK if locked at normal height and holding there, but your caution with regard to speed is a good one, if only for your safety and that of your passengers should an air bag go pop!
Unless it is the SAS causing the faults, sounds like your compressor has had it or you have a leak somewhere in the air system, probably a bag, which may be holding OK due to being at normal height, or compressor working overtime.
So for me, the choice is yours, either keep on until the problem really manifests itself, or stop now and get recovered and let your indie at it.
Do not drive if a corner drops or you hit the bump stops, that really will cause some damage, or make safe driving difficult.
May be worth a soapy water test to check for bubbles, although really need off road height for that? .
Post #254853 17th Apr 2014 1:32pm
Mustard
Thanks for your input Joe. Im miles away from home at the moment so I'm hoping to just limp round in it for the next few days and then next week get it into the indy to hopefully get it resolved Thumbs Up
Post #254905 17th Apr 2014 10:11pm
666tur
United Kingdom 2012 Range Rover Vogue SE TDV8 Zambezi Silver
I have had the same problem. My car had been stood for 10 days, started and got the dread bong with susp inactive. It's locked out in normal height.
I am hoping the battery voltage is to blame, it's the original battery. I have also recently had regular trans failsafe message, HDC inactive etc. I will take to my local dealer for diagnosis. 2012 4.4TDV8 VSE
2004 TD6 132k miles- SOLD
1995 Land Rover Defender 110 Tithonus Ex Military
1995 Land Rover Discovery 3.9i V8 manual
Post #255126 19th Apr 2014 11:49am
Mustard
The fatty went in to Indy today and has been fixed Very Happy
Faulty ABS sensor, passenger front side, relatively inexpensive to get sorted.
Apparently the faulty sensor was a Censored to remove but its done and I have adjustable air suspension again Thumbs Up
Post #256939 29th Apr 2014 10:21pm
aclr8r
United Kingdom 2009 Range Rover Westminster TDV8 Santorini Black
hdc/suspension inactive
Hi all,
Just to add to this topic. had the same. Pixies f Censored g around with the chimes, hdc inactive/suspension inactive. Read and cleared faults only for the pixies to wake up again 15-20mins into driving.
Took to my local indie and told that the steering angle sensor was shot. Booked ff in and left 360.00 lighter in the wallet region.
All running like a dream again Thumbs Up . No doubt some more pixies will hatch and cause mischief in the future but that's to be expected with lr's. If you don't know what you're doing - do it quickly!
Post #271284 16th Jul 2014 7:36pm
Dijit
Scotland 2007 Range Rover Vogue TDV8 Java Black
Hi 666tur.
You wrote back in April, "I have had the same problem. My car had been stood for 10 days, started and got the dread bong with susp inactive. It's locked out in normal height.
I am hoping the battery voltage is to blame, it's the original battery. I have also recently had regular trans failsafe message, HDC inactive etc. I will take to my local dealer for diagnosis."
Sounds exactly like mine and I'm stuck. Any clues gratefully appreciated. Bow down Rehab is for quitters!!!
RR 2007 3.6 TDV8 Java Black *
RR 2007 3.6 TDV8 Zermatt silver *
RR 2000 P38 4.6 Met red *
Mercedes 300TE 4-Matic *
Jaguar 420 (1969) *
Nissan 300Z
Citroen XM 2.5TD X 6
Bentley Continental R
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Am told the ones with a * are to be offered for sale! 😳
Departed
LR 1992 110 2.5TD
RR 2000 Holland & Holland 4.6 LPG
RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue
RR 2002 4.4 V8 Zambesi Silver
Post #278246 30th Aug 2014 10:46pm
