Home > Maintenance & Mods (L322) > Aarrgghhh
Dave ray
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Aarrgghhh
Patience wearing thin first inactive suspension now steering retract packed in not sure weather to get shut or carry on chucking cash at the thing 2003 v8 is it worth it and the coolant leak which as driven me mad it loses none then a little bit and lots
Post #278070 29th Aug 2014 5:50pm
Welshdragon
Stick with it pall for now, Green ovals are never cheap to run when they go wrong Sad you not sorted that coolant leak then? could be that O ring just below rad. If it dont work.......burn it!
Post #278075 29th Aug 2014 6:24pm
Dave ray
Local indie couldn't trace the leak love the car it's my second but feel like pulling my hair out sometimes
Post #278079 29th Aug 2014 6:35pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
I've had various coolant leaks on mine over the last couple of years. The first was a hose which had become displaced and had a groove cut into it by the bottom pulley. Solution; two inch gaffa tape. (After replacing the hose of course!).
Second leak was a pain but I eventually traced it to a hairline crack in the coolant reservoir. This is common and can be hard to see as it tends to happen when under pressure when driving then the heat causes the leaking coolant to evaporate so you can't see where it came from. Solution; kitchen towel to dry the outside of the reservoir then sitting in the drive at 2500 revs for a while to build up pressure then using kitchen towel again to see if there was any leakage. New reservoir takes less than 30 mins to fit.
Third leak; that annoying little hose at the back of the engine. Another common problem. I let someone else replace that for me.
Then there was this months issue. Water pump relieving itself with the engine not running. Again a bit of DIY which took a few hours but it is well worth the time I spent.
I guess what I'm saying is that despite all of the above I still love my V8 and the roar (and I do mean roar!) it makes when I set off at speed.
Keep at it and have a look at the areas I have outlined. Hopefully this helps!
Chris
Post #278144 30th Aug 2014 9:34am
pld118
Presume you've also checked the coolant expansion tank bleed screw as the source of coolant loss Dave Ray?
If not, the below thread might help to solve the problem.
ps... If you do read the thread you'll also note that Bellini's hastily scripted song 'lyrics' have yet to go mainstream as an up to date cover version of the Ray Parker Junior classic! Laughing
http://www.fullfatrr.com/forum/topic21436....p;start=30
Post #278150 30th Aug 2014 9:49am
