Home > Maintenance & Mods (L322) > Air Sususpension inactive - Warning light
Diver Bryn
United Kingdom 2005 Range Rover Vogue Td6 Tonga Green
Any ideas how to correct my FFRR TDV6 (2005) Looking like a dog cocking its leg?
Suspension is lower on left and high on right hand side.
I suspect a height adjuster problem but which one?
I have carried out the normal reset (Disconnected negative lead from battery and left for 15 minutes reconnected and turned steering wheel full lock left and right) no Joy carried out same again still no joy.
Car drives, however it is now parked up awaiting fitter to inspect. Diver Bryn
Previous Transport:
Honda CB250n
Toyota Starlet
Renault Fuego 2 ltr TX
Fuego Turbo
BMW 528i
Escort RS Turbo
Capri 2.0 L Ghia
Kawasaki GT750 P4
Mini Metro
Ford XR2
Volvo 740 TDi Estate
Mondeo Tdi
Volvo V70 Tdi
Mercedes E300 TDI
Mercedes E320 Cdi
Mercedes S320 Cdi
Land Rover Discovery 3 TDV6
Mini Cooper Diesel
Mercedes Vito Van 111
Range Rover TD6
VW Golf 2ltr GTD 2015 Year
2016 Audi Q7 Sline 3ltr 272Bhp
Post #277962 29th Aug 2014 8:21am
stcstc31
Ireland 2005 Range Rover SE Td6 Atacama Sand
sounds like same thing i had
one of the bags was toast, so had to replace. was done under warranty as only just had the card
i was advised not to drive as the compressor will work overtime and burn out
Post #277966 29th Aug 2014 8:53am
Diver Bryn
Thanks will keep you posted. Will be keeping FFRR off road, until rectified another great off-roader by Land Rover! :evil: :evil: :evil: Diver Bryn
Previous Transport:
Honda CB250n
Toyota Starlet
Fuego Turbo
BMW 528i
Escort RS Turbo
Capri 2.0 L Ghia
Kawasaki GT750 P4
Mini Metro
Ford XR2
Mondeo Tdi
Volvo V70 Tdi
Mercedes E300 TDI
Mercedes E320 Cdi
Mercedes S320 Cdi
Mini Cooper Diesel
Range Rover TD6
Post #277968 29th Aug 2014 9:12am
mjdronfield
This is a hard fault, ie it will not reset itself even when fixed without being reset with a diagnostic tool. On the plus side, the system is now inactive, so the compressor will not run, so whilst not ideal, you can move it about or drive it onto a low loader etc.
It could be a height sensor issue, the system will deactivate if it gets non sensical inputs from the sensors. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #278072 29th Aug 2014 6:18pm
Diver Bryn
Thanks fella's the height adjuster had to be realigned after it was inadvertently repositioned when the bottom torsion bar was replaced last week. Thankfully a two minute job and no serious expense.. Diver Bryn
Previous Transport:
Honda CB250n
Toyota Starlet
Fuego Turbo
BMW 528i
Escort RS Turbo
Capri 2.0 L Ghia
Kawasaki GT750 P4
Mini Metro
Ford XR2
Mondeo Tdi
Volvo V70 Tdi
Mercedes E300 TDI
Mercedes E320 Cdi
Mercedes S320 Cdi
Mini Cooper Diesel
Range Rover TD6
Post #278215 30th Aug 2014 6:04pm
mjdronfield
Result. Always good to hear.
Interesting car history.......
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #278217 30th Aug 2014 6:26pm
