![]() | Home > In Car Electronics (L322) > Which C Tek battery charger? |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
Message from seller
mmiata Member Since: 12 Jul 2013 Location: Budapest Posts: 104 ![]() ![]() ![]() |
I don`t know if anyone is worried about AGM battery recondition (which according to vendor differs from normal battery recond, and from AGM charging as well).
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7878 ![]() ![]() ![]() |
J evro, your man is right. If all you ever want to do is maintain your battery, the 3.8 will be fine. It's a 3.8 on ctek webpage. If he has a 3.6 is it an older model ? Or a typo....
Thanks chaps ,
I think it's some later gel type arrangement. Don't know much after that myself.
Yes sorry being lazy , but I'd rather hear from someone on here as they sometimes add more info/ experiences I find |
Nothing like what I thought then. Never really needed to know. Thanks for the info.
What are the problems (if any) of using a higher amperage batterie conditioner/charger ? 2008 MY Supercharged
No problem, it will charge it faster. If you compare a 5 amp to a 7, the 7 should be 40 % faster on paper. Though won't get that much increase in the real world. 2011 Range Rover Vogue SE 4.4 TDV8
Grrrrr
