Home > In Car Electronics (L322) > tv and reversing camera
stcstc31
Ireland 2005 Range Rover SE Td6 Atacama Sand
is there anywhere with a list of model numbers of parts for installing the hybrid tuner and reversing camera into a 2005 touchscreen
Post #277775 27th Aug 2014 7:21pm
quabba
Scotland 2005 Range Rover Autobiography 4.4 V8 Java Black
Very interested in this. I've heard that a hybrid tuner cant be fitted to 2005MY as it's a bit of a mix of equipment/software used. I was hoping this was incorrect.
Post #278420 1st Sep 2014 9:37am
If you have a touch screen FFRR and factory fit TV the hybrid tuner is just plug and play . 2008 MY Supercharged
Post #278425 1st Sep 2014 10:42am
stcstc31
i have touchscreen but no tv or gps fitted, would the loom be there to connect it by default?
Post #278426 1st Sep 2014 10:47am
quabba
I tried a hybrid tuner in mine, but when I clicked on the tv option nothing happens, looks like its disabled. Also the sound from cd stopped Confused
Post #278635 2nd Sep 2014 2:02pm
Discotigger
^quabba,
What model number do you have on the hybrid tv unit? There's been loads of threads re: the correct and incorrect tv tuners to get...it's possible you've either got a wrong un, or the tv tuner could be broken.
Did you have an analogue tv unit in to begin with, as if there was an analogue unit installed then the tv option will be enabled in the headunit settings? If not, I think you may need to enable the tv unit in the CCF, so would need diagnostics kit like an IID Tool.
Post #278644 2nd Sep 2014 3:06pm
quabba
Yeah, got the old analogue tuner installed. all I get is static though obviously Wink
the tv option works with that installed but not the hybrid tuner
I will find the model number - can remember it does say PAG Hybrid on it though and has the Jag and Range rover emblem
sure its something like Aw93-19C063-AG
Post #278645 2nd Sep 2014 3:08pm
Discotigger
The model number should start:
AH42 19C063 xx (the last two suffix letters are the model variant, e.g. my tuner has the suffix AH as it came out of a 2010 RRS)
Might also be worthwhile checking the country setting on the tv, make sure it's set to united kingdom, and possibly check you've got a good digital signal near the FF when switching to the tv. Thumbs Up
Post #278651 2nd Sep 2014 3:16pm
quabba
Cant even get into settings with the hybrid unit though. like I say, pressing tv does nothing
Post #278652 2nd Sep 2014 3:17pm
quabba
What year is your rr Discotigger
Post #278653 2nd Sep 2014 3:18pm
Discotigger
MY2005 TD6, Denso touchscreen Satnav and (originally analogue) tv.
I had the analogue unit in originally and got the hybrid unit (AH42 19C063 AH) off fleabay, plug and play as I said, but I checked out the threads on this site before taking the plunge, as there are loads of hybrid units on fleabay that don't work in the UK, even if the sellers claim they do.
Post #278656 2nd Sep 2014 3:26pm
Discotigger
quabba,
when you say pressing the tv button does nothing, do you mean the tv button is 'greyed out' on the touchscreen?
If that's the case, then check your wiring to the unit (fuses, etc.), as it sounds like the tv unit is possibly not getting any power or could be faulty.
Post #278659 2nd Sep 2014 3:28pm
quabba
Not sure if it's greyed out. Can see it ok but as soon as I press it - only thing that happens is any music being played stops. I then have to select cd or radio to get sound back.
As soon as I plug analogue back in tv option is available again
Post #278661 2nd Sep 2014 3:36pm
Discotigger
Hmmm, sounds as though you've got a wrong un there I'm afraid.
As I said, check the model number first, anything with AH42 19C063 xx should work okay, anything else probably won't.
If the model number is correct, then the unit is faulty.
Post #278668 2nd Sep 2014 3:47pm
markc1973
Northern Ireland 2005 Range Rover Vogue Td6 Java Black
Hi fellas
I'm new to the forum and in the process of upgrading to digital, however I'm hoping to sell my analogue unit. Has anybody done this and if so what sort of price should I expect. I don't think there are many countries running on analogue.
Post #279133 4th Sep 2014 10:06pm
